Question about MXL Audio Players & Recorders
This mic is sensitive. I have moved in a closet in my house. How do you deal with this mic when it still picks up so much air. What can I do?
    Problem Solver:
  • 7 Answers
Your mic may be sensitive but its gain is set in the mixer or computer to which it's connected. I don't know what you mean by "too much air" but if you mean "room sound" there shouldn't be much in a closet unless it has all hard sound reflecting walls. You will need to provide a better description of the problem.
Posted on May 13, 2015
2 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Loose Mic Head
Hi intel
Aahhh the joys of second hand gear. wow, the holes have been enlarged... may be that the original screws are not fitted to it also. OR less likely, mic may have become this way from years of being pulled in and out of a bag, with loose screws the whole time. It will rattle if the screws are a loose fit, can only suggest to you at this point try and get some new screws for it. or short on that (more drastic measure) to resecure the head of the mic with a small dap of clear nail varnish about each screw head. the varnish will hold well enough, but may present an issue getting the mic apart again, this depending entirley on how much of the stuff you have applied. Less is better :). other than that, there is not really a fix. Hope this advice helps you.
regards
robotek
Posted on Oct 31, 2008
How can I reduce the sensitivity of the mic?
Plug the microphone hole foam rubber or cotton...
Jan 29, 2015 | Plantronics Voyager Legend
Lenovo essential mouse pad too sensitive
go to mouse settings in Control Panel, then choose your touchpad and change the sensitivity.
Feb 04, 2013 | Lenovo G580 Laptop Computer - 268938U -...
Just received brand new Austin Allergy Machine Friday April 29, 2011. Funny odor coming out of outgoing air. I have mold, smoke, pet dander, allergies, chemical sensitivities to deal with and I don't think...
Have a Indoor air quality inspection preformed in your house. Then spend the money to have a air purifier installed for the whole house. In this day you often get what you pay for. It may be possible that your Doctor can provide you with a prescripition for the Air purifer to be installed.
May 02, 2011 | Austin Allergy Machine Air Purifier
Static noise when playing back recording, sounds like the wind
This camera has a single Mic - make sure your finger isn't over it though -- try making a recording in a closed room - no wind noise - is there still static ??
Go through settings and see what choices there are -- like outdoor , indoor . close to subject etc.
My CAM had a close up and background button - which was a sensitivity setting - and the background setting picked up EVERY sound from miles around and filled the tape with noise. The close up setting only picked up sound from bout 2 - 3 meters.
Do you also have an external plug for a Mic ? this would also check whether it's the camera mic or recording that is at fault ??
Ray
Mar 07, 2011 | Samsung SC-X105L Memory Card Camcorder
Hi having trouble when i plug guitar or mic into the neo. when i raise the trim to hear the input, the re is a big buzzing sound that just wont go away... any ideas?
Do you have any light dimmer in the house?
Are you using humbucking guitar pickup?
Do the the buzz change when the move the guitar around, it may be picking up radiate magnetic field from the transformers of the equipment.
The preamp is very sensitive with very high gain circuits that amplify signals in the millivolt range, so godd shielding and grounding is needed.
Dec 31, 2010 | Audio Players & Recorders
I know that the m-audio nova is a studio recording microphone , but i would like to know why it is not recommended for stage use ?
I would guess that the mic is a condensor type. These mics are much more sensitive to transients, and they tend to pick up a lot of ambient sound around them. In contrast, dynamic mics, such as the Shure SM 58 have become the standard live mic because their pickup pattern and response tend to be concentrated close to the singer, thus rejecting the ambient noise that condensors pick up. The live sound environment is very different acoustically than the controlled studio environment, and therefore, mics are chosen to accommodate the different acoustics.
Oct 06, 2010 | M-Audio Nova Professional Microphone
Leaks when cleaning the bowl. Bowl moves a bit. Plumber was afraid to tighten bolts too much for fear of breaking bowl. How tight?
Leaks at the floor or the tank where it meets the base behind the seat?
Generally tight enough to sinch it so as not to leak.
If the whole unit moves on the floor the wax ring may need to be replaced. If the tank leaks be sure the bolts are tightened evenly with new gaskets sealing them inside the tank. Tighten the nuts evenly until it stops moving freely and the leak should stop.
Dec 17, 2009 | Toto Aquia II Dual Flush Toilet
How to make a d-link 264 ob into a repeater I have a three story house with wireless on the ground floor and the signal is very poor at the top. I want to repeat the signal on the second floor.
Move your wireless to the second floor or add a second wireless router to your second floor. Use CAT 5 or 6 cable. Run it in a closet or cold air return. Use the special cat 5 or 6 for cold aire return use. Do not put it in a heated duct.
Dec 09, 2009 | Computers & Internet
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
Loose Mic Head
Hi intel
regards
robotek
Sep 06, 2007 | AKG C451B Professional Microphone
491 people viewed this question
Top MXL Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Will Godwine
Are you a MXL Audio Player and Recorder Expert? Answer questions, earn points and help others
