I have 5 columns of numbers on my screen that I'm trying to watch tv and they won't go away what do I do
Vizio tv dropped a channel, won't rescan
Try with the remote to direct enter the channel number (with the number buttons and or enter) If set makes it there go into menu for option to manually add it to the set memory.
Not likely a problem with your set.
Dec 17, 2012 | Vizio RazorLED M260VA 26" LED-LCD TV -...
My screen does not cover the whole screen. It is not on widescreen mode, but it is a shortened picture and some of what I am watching is cut off.
A lot depends on what the TV station cuts off also.
If they are transmitting a 5 X 4 picture, your TV will try an reproduce it giving cut off edges or top and bottom. It won,t fit properly.
Hope that helps to explain it.
Jan 22, 2011 | Sharp LC-32SB24U 32 in. LCD TV
A black box randomly pops up on my tv screen constantly...
It part of the caption functions is on.Tries find in ur tv menu,goto captioning functions like CC1,2,3 and Text 1,2,3.Turn it all off.These radom black boxes and trying typing somethings,should stop.
Jul 20, 2010 | Olevia 237T 37 in. LCD TV
Black box on JVC screen
a black box is covering my tv screen except for around the edges. I can use the dvd player, but i cannot watch cable. it is as though there is a security feature to block tv, but i cannot get it to go away!
Jul 11, 2009 | JVC AV-32D305 32" TV
Black rectangle appears on screen while trying to watch movie
This happens all the time, on your remote, go into the Menu and disable Closed Captions. It will go away after that.
May 01, 2009 | Sony DVP-NS575P DVD Player
Why when I watch my new 32in sharp flat screen I seen lines ?
What you need to do is call sharp and make them aware of this problem. If you are under warranty, they will take care of it. If the model number of your tv has SB in it, you will have to take the unit to one of their authorized service centers in your area(which could be anywhere from 1-45 miles away from you). If you have a AQUOS unit, they will send someone to your home, either way, they will take care of it. give em a call, you have a service issue on your hands. good luck 2 u
Jan 31, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Thin green line on right side of screen when watching through HDMI cable...line goes away when watching through reg AV inputs
You should check if you could adjust the screen size or posistion. If that don't work try using another (newer) HDMI cable. If everything feals go back to your store and claim a new tv. Then it is the hardware inside the tv, you will have warrenty on that.
Dec 24, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Nov 25, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Xbox 360 stretched screen out and cannot fix it now
Have you checked the aspect ratio?? May be that when the kids had the X-Box hooked up they simply changed the aspect to zoom.
May 22, 2007 | Sanyo DS20425 20" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
