Question about GE Kitchen Ranges
After power outage code f81 cal , ovens don't work. Try disconnecting several times for 5 min , no change. What else can I do??
  • 46 Answers
SOURCE: F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Posted on Mar 10, 2008
aborcass
  • 2651 Answers
SOURCE: Amana The Big Oven Gas
apepars ther eshould be more then an f1 but heres the error codes anyway
http://www.fleetappliance.com/information.php#Amana4
Posted on Apr 04, 2008
SOURCE: Inglis Niagara oven not working since power outage
try pushing cook and hold button once until lock comes on, then push cook and hold button again. The lock should be removed.
Posted on Sep 08, 2009
  • 291 Answers
SOURCE: electric oven and stovetop do not work, clock and oven light do.
Sounds like you are only getting 120 volts instead of 240 volts. Either a house electical problem or wiring in range. First go to your breaker and turn it off and on three times and give it a little extra push each time you flip it. ( You can actually flip a breaker off and on without resetting a blown breaker if you doni't push it all the way off and all the way on. If the breaker throws itself off do not reset it. You have an elecrical short in your house or range. If resetting the breaker does not work then you need to test for 240 volts coming into the range. We don't recommend you do any electical testing unless you know what you are doing with electicity. If you have 240 volts going to the range then unplug your range and remove the backing panel off the back of the range. Look for burned wiring or terminal blocks. If there is nothing obvious then you need to know how to read a wiring schematic and use a electical tester to go any farther. Let me know if this helps. Good Luck, Appliance Specialists
Posted on Dec 15, 2009
  • 963 Answers
SOURCE: GE Range oven don't work. Igniter comes on, no gas is released
I recently had a problem with my gas oven, where I could see the igniter glowing but the gas was not coming on, just like your problem. I found out that the igniter needs to draw a certain level of current to allow the gas valve to open. Although I could see mine glowing, it had broken down enough over time to where the current draw was no longer enough. And the igniter is the "weakest link" in the system.
Replace the igniter. It worked for me!
Posted on Jul 29, 2012
I have a 2001 oldsmobile sihouette I disconnected negative battery post for ten min then put back then I parked van now when I go to start it securety lock is on and I can't start car and it reads cal...
you have to do that cycle 3 times,battery needs to fully charged.
Hood to stay closed,doors also(roll down the drivers window)
Kill the DRL headlights if possible(try putting the E-brake on)
Crank and leave key on,10 min or till light goes out,then key off,,no need to wait 5 min here,crank again.leave key on,,,,,3 times.
By the way,disconnecting the battery in that vehicle will not do anything like clear codes or memory,may need the radio code in the owners manual also.
Jan 07, 2014 | Cars & Trucks
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
Tip
Motorola Secret Codes
<span>Motorola L6:<br />-----------------<br />hold * 65512890 for reset<br />hold * 5806 sw version<br />hold * 487989 NS lock menu<br />hold * 482896 CP<br />hold * 574243 NS<br />hold * 967678 SP<br />hold * 362628 IMSI<br />hold * 787090 Lock net level<br />hold * 787292 Lock net level<br /><br /><br /><br />Reset L7 security code without any cable<br />------------------------------------------------<br />press menu button enter 6 time 0 and then press ok<br /><br />*#06# IMEI<br />in permament test mode<br />(* hold 2 sec)<br />***113*1*[OK] net monitor<br />T205/T19x (ACER)<br />*#300# OK List the Software and Hardware version<br />*#301# OK Full Keypads functional Test<br />*#303# OK Set Default Language to English<br />*#304# OK Set OFF engineering mode<br />#304*19980722# OK Set ON engineering mode<br />*#305# OK Location: 1 OK<br />*#307# OK Engineering Test Mode<br />*#311# OK Phone code changed to default code<br />*#400# OK ADC, Cal val*<br />*#402# OK Adjust Display Intensity / Contrast<br />*#403# OK List the Manufacturing Informations<br />19980722 OK Master Unlock code for Phone and Sim Lock<br />*#302# OK Acoustic test*<br />7.1 Greeting<br />7.2 Main VlmGain<br />7.3 Input Cal<br />7.4 Output Cal<br />7.5 Side In Gain<br />7.6 Vox Gain<br />7.7 Min Mic Engy<br />7.8 More<br />(a) In Vlm Gain<br />(b) Aux Vlm Gain<br />(c) Silence Prd<br />(d) Supp Prd<br />(e) In Volume<br />(f) Out Volume<br />(g) Icon<br />(h) Image<br />(i) Animation<br />*3370# EFR ON (enhanced full rate)<br />#3370# ERF OFF<br />*#72837726# OK Confirm ?, Data saver<br />1234 OK Phone code default<br />*#0000# OK Setting saved, restore set phone do default language<br />*#0048# OK Fast change polish langpack<br />*#0007# OK Fast change russian langpack<br /><br /><br /><br />MOTOROLA 3xx<br />------------------------<br />*#06# and quick 'menu-key' and 048263* (Push the key quickly!)<br />and entering at field "OPTCODE" you must try several times.<br />If not working try with MOTO TEST CARD inserted.<br />Security code - 32*118*1*0*0<br />Model - 32*279*1*0*8<br />Flex ver - 32*383*1*0*0<br />Master Reset - 18*0<br />Master Clear - 18*1<br />Set band GSM 900 - 10*0*3<br />Set band DCS 1800 - 10*0*4<br />Set band PCS 1900 - 10*0*5<br />Set dual band GSM 900/1800 - 10*0*6<br />Read band - 10*1*0 =&gt; 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS<br />User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/<br />Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/<br />47*4*1*0*9*081A32547698103254 =&gt; IMEI=123456789012345<br />it is possible to change IMEI<br /><br />ENJOY</span>
on Jul 11, 2011 | Cell Phones
Tip
MOTOROLA CODES
>>All Motorola Secret Code<<
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
*#06# IMEI
(* hold 2 sec)
T205/T19x (ACER)
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
#3370# ERF OFF
MOTOROLA 3xx
Master Reset - 18*0
Master Clear - 18*1
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI.........
on Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
Cant clear code or use oven after small power surge - stove top still works. GE web site does not have a F81 code they have an F8 and F1 which both say problem with keypad and electronic control needs to...
You didn't post model, but with a surge you probably looking at replacing the ERC. Does the manual say to unplug to reset, or check again on reset the control.
Some have this for reset, can't hurt to try.
  • Press the BAKEand BROIL HI/LO pads at the same time for 3-5 seconds until the display shows SF.
  • Press the COOKTIME and BROIL HI/LO button (on some models press Broil only, refer to your use and care manual). The display should show C. Press the button again until F shows in the display.
  • Press START to complete the change.
  • If this clears control, do it again to reset to Fahrenheit.
    This way actually resets for a error also besides temp.
    You can check the price of a control here,
    http://www.repairclinic.com/
    And you can google search for more places to shop prices.
    Mar 30, 2013 | Ovens
    What to do?
    hi friend,
    Look at these service phone codes of Motorola mobile, may be it will help you in your mobile phone settings
    *#06# imei
    in permanent test mode
    (* hold 2 sec)
    T205/T19x (ACER)
    *#301#­ OK ­ Full Keypads functional Test
    *#403# OK List the Manufacturing Information's
    7.1 Greeting
    7.2 Main VlmGain
    7.3 Input Cal
    7.4 Output Cal
    7.5 Side In Gain
    7.6 Vox Gain
    7.7 Min Mic Engy 7.8 More
    (a) In Vlm Gain
    (b) Aux Vlm Gain
    (c) Silence Prd
    (d) Supp Prd
    (e) In Volume
    (f) Out Volume
    (g) Icon
    (h) Image
    (i) Animation
    #3370# ERF OFF
    MOTOROLA 3xx
    Master Reset - 18*0
    Master Clear - 18*1
    it is possible to change phone's imei
    or u can even try last 4 digits of ur mobile number
    hope this helps u
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Motorola Mobility RAZR V3
    Air conditioner compressor runs for about 1-2 min, then cuts off
    well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
    Jul 23, 2009 | Danby Portable Air Conditioner
    F9 error
    hi there,
    can you tell me the model # on your stove please?
    Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
    F8 code
    It is a " Lock Switches" Display you can try to disconnect power and resetting. But it is possible with the power outage you may need to replace
    Jul 24, 2008 | Kenmore 41389 Electric Double Oven
    Electric Kenmore Ultra Bake Oven
    I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
    As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
    Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
    Kitchen Ranges Logo
    369 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
