Question about Dryers
What is the fix for E63? Have a 2 year old affinity dryer
  • Dryers Master
  • 5,166 Answers
The E63 error indicates an open circuit for the heating element. The wiring or the heating element may be bad. Check the wiring for any shorted wires (touching the cabinet); replace any damaged wiring. Otherwise, replace the heating element.
You should check that the venting for the unit isn't blocked. Usually the element lasts longer than 2 years. However, the heating system is only covered by the one year warranty.
I hope this helps. Please add a comment with the model number if you want more information on the replacement parts.
Posted on Apr 22, 2015
  • Tosca Fernandes
    Tosca Fernandes Apr 23, 2015
    E 64...i was wrong about the previous number
    What is fix for E64?
    Thank you.
    Fridlgidaire Affinity- FASE7073LW
  • Cindy Wells Apr 23, 2015
    The E64 error is still a problem with the heating element or the high temperature thermostat. The heater is available here:http://www.appliancepartspros.com/frigid... . The thermistat is available here:http://www.searspartsdirect.com/Frigidai... . I hope this helps. Cindy Wells
Gas dryer melting clothes
One of the issues that can cause this is lack of airflow. Make sure that you have no obstruction in the output air ducts. This includes that whole system that is part of the building. Make sure that the flame is blue, if it is not, the jets or gas pressure needs to be adjusted.
Dec 09, 2013 | Electrolux Frigidaire Affinity 7.0 cu. ft....
Affinity dryer burning clothes
Probably a seal around the drum or blower needs to be replaced.
Affinity service manual
Nov 24, 2012 | Frigidaire Affinity FAQG7011KW 7.0 Cu. Ft....
ERROR CODE E64 FOR FRIGIDAIRE AFFINITY
Please CALL Frigidare. We have had the same problem with our dryer and now the washer quit! Our set is only 3 years old! With all of the problems reported on the Internet there should be a recall on this set! They need to be informed! I am highly disappointed in the short lifespan of the Affinity Washer and Dryer. Dont know if I would purchase this brand ever again!
Mar 02, 2012 | Electrolux EIED55H Dryer
Error code E68 shows right after I start my dryer which is 3 years old. trash it or fix it?
you can try to reset it by unpluging it for about 15-20 mins to let it reset itself hope that work.
Dec 17, 2010 | Frigidaire Affinity ATF7000ES Front Load...
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Frigidaire Affinity dryer (8months old) dries fine, but always has heavy moisture on the inside of drum, and door.....didnt do this when purchased.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 18, 2010 | Frigidaire Dryers
Dryer making a buzzing noise
It sounds like your motor has gone bad....it will buzz or hum when it is trying to start and cannot...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call " -
Apr 13, 2010 | Frigidaire Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
