Question about Sony Televison & Video
Sony stereo component ststem parts SEN-301
LOOKING FOR FLAT CORD WITH 11-5-5 PIN CONNECTORS AND FLAT CORD WITH 11-11-5-PIN CONNECTORS
5 Suggested Answers
charcois
  • 763 Answers
SOURCE: playing sony mp3 walkman through stereo component
use adapters to connect the cables from your mp3 to your stereo. you can buy these adapters on some eletronic shop.
thank you for using fixya
CHARCOIS
Posted on Nov 18, 2008
  • 56 Answers
SOURCE: looking for cable connector pin
Try MCM Electronics, not sure but might have something that works, GOOD LUCK
Posted on Jan 26, 2009
  • 276 Answers
SOURCE: Hi, im looking for connecting
ment you can do there is make your own wire soldered on the inside of your computer by cable that there
Posted on Dec 05, 2010
  • 6771 Answers
SOURCE: HST-221 Sony Stereo Component system - Lost System Control Cable
This is a long shot go to www.ebay.com Type: make and model and scroll through the listing.
Posted on May 18, 2012
Cdp c221
This was sold as part of a stereo system. The CD part of the instruction booklet starts at this web page (page 15 of the manual)
http://www.manualslib.com/manual/661041/Sony-Sen-421cd.html?page=15#manual
Jul 31, 2014 | Sony Audio Players & Recorders
Where can I find a Megavision MV173 LCA01F "monitor to computer" connection cord?
Isn't it a VGA cable?(15 pins-3 rows of 5 pins,slightly staggered.There is a 15 pin D-sub connector(2 rows of pins)-usually for extending a joystick cord on a PC.
Dec 16, 2012 | MegaVision MV173 (Black) 17 in. Flat Panel...
Looking for stock remote
The stock remote for the Onkyo P-301 is a RC-200s because I have the same preamp.
Jul 30, 2012 | Onkyo P-301 Stereo Preamplifier R1 Preamp...
May 18, 2012 | Audio Players & Recorders
I need the wires to conect two speakers sony sa-va100r
Which two speakers?
http://www.retrevo.com/support/Sony-SA-VA100-Speaker-Systems-manual/id/22986ci669/t/2/
The speakers themselves appear to use standard spealer wire with bare ends. Just get a roll of lamp cord at the hardware store and cut it to the length you need.
Between the two front speakers they require a standard RCA stereo audio cable.
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Audio-equipment-Parts/Model-SAVA500/0996/0311400/50017803/00001
If you're needing the flat cable the link above is a breakdown of the various components. Perhaps you could contact them and describe which 'wire' you need.
Some other possibilities...
1-777-117-11 CORD (WITH CONNECTOR)(15P)
http://www.encompassparts.com/products/?1-691-777-11
http://www.partstore.com/Part/Sony/Sony/175134713/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=SAVA100
Feb 01, 2011 | Sony SA-VA100 System
Use sony wega KV-HP21 as Pc monitor.
if it has a 15 pin connector on the back, very easy. just connect to that the same as you would a computer monitor. if not, you will have to get a VGA to composite connector, which looks like your computer cord on one end, and has an RCA connector on the other.
Feb 03, 2010 | Televison & Video
Stereo integrated amplifier a30, turns on some times
A few things to check:
- a bad power cord or connector to the unit on the cord (if any), bad power connector on the unit (if any) or bad connector soldering on the circuit board (replace cord or resolder/replace connector if necessary)
- main power switch could have dirty contacts or some damage (needs to be cleaned or replaced)
- an electrolytic filter capacitor (any of them) could be dried out, blown (bulged at the top), badly soldered or otherwise faulty (should be replaced if faulty and resoldered if there is a loose solder joint)
- a connector (any of them) could be loosely plugged, oxydized or have bad solder joints on any pins (connections should be checked, dirty contacts cleaned, loosely soldered pins resoldered)
- any other components could be poorly soldered or damaged (resolder or replace, as necessary - might require technical service to establish which components are bad, if any)
Note that the problem may be any of the above, a combination of any of the above or something entirely different, i'm just pointing to some possible causes/solutions.
Hope you can fix it.
regards
Triarcuate
Sep 21, 2009 | Audio Players & Recorders
Sony KV36XBR800 standby blinks 4 times
The 4 blinks usually mans that there is no vertical deflection signal. Look for a small flat Ic with about 11 pins that may be marked LA7837 or something similar. Resolder the pins on that first. If that fails to resolve it, replace the IC.
Keep me posted.
Dan
Oct 15, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Question about a Shelf Stereo System
You can use any analog Audio input out of 3 at rear of this system to listen laptop sound. Audio Cord is required to hook up and its look like red-white RCA pins at one end and other end is like headphone stereo jack for laptop. Audio Cord is available at Sony Part Center.
Hope above info will help you.
Sep 06, 2008 | Audio Players & Recorders
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
