Why won't my washer fill? Locks lid and makes sounds for a second and then after a few seconds, lid unlocks and green fill light flashes without filling.
Model #110-21102010
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inlet valve
Posted on Apr 26, 2015
  • 249 Answers
SOURCE: Smart drive Pride 5.5
can you empty the machine completly of water, and start again.you could try unpluging it for 2 mins it might reset it self best of luck!!!,close,eire
Posted on Dec 15, 2007
  • 79 Answers
SOURCE: Maytag Neptune washer model #MAH4000AWW,
Check out your motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
These kits are offered on the www.neptunewaxmotor.com order form and they ship UPS Ground.
This kit takes about an hour to install.
Don't forget to see the info on the website regarding the defective door latch wax motor that will eventually fail and damage your machine control board.
Posted on Jul 15, 2008
SOURCE: GE WSSH300G0WW front load washer
Had same problem with GE wssh300 front load washer. Removed two screws from front bottom panel (under washer front). Pulled off panel, loosened screw from a seal ring on the rubber flex hose going to a 4" square plastic housing. Reached down inside and found a ton of lint (probaby a 2" balls worth) jamming outlet. Removed lint an works geat. Very easy to do by tilting front of washer up and putting supports under front to keep elevated. Be careful to make sure supports are sturdy washer can't dop when servicing.
Posted on Aug 25, 2009
  • 220 Answers
SOURCE: Maytag Bravo Washer flashes F50 code
Most likely a bad machine control,can also possibly be a motor per whirlpool but I have never had to change a motor,changed a lot of machine controls.
Posted on Sep 01, 2009
machinetech7
  • 1344 Answers
SOURCE: Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
Posted on Jun 02, 2012
Water will not fill my washer machine
  1. what worked for me was banging on the top right where the control are - there is a chip in there and every now and then that will happen to mine and I bang on it a few times with the palm of my hand.
Jun 26, 2014 | Whirlpool Cabrio WTW5600XW Top Load Washer
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
May 30, 2012 | Maytag Washing Machines
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
May 21, 2012 | Kenmore Washing Machines
Batteries were wearing out and were replaced. Has not worked the same since. Green light on the back continually flashes. When code is entered to unlock sometimes it works on the first try-- sometimes the...
I recommend that you got to this link:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
and contact Weiser Lock for technical assistance. Yours is an uncommon problem.
Sep 20, 2011 | Weiser Lock GED1460X GED1460X15A Antique...
Neptune TL locked lid light stays lit
foxste
I will give you a few things to try that are non technical and let’s see if the Control Board will let you in Service Mode. If so we will try lock and unlock the washer in Service Mode.
The Service Manual for reference. Sears Parts Direct for reference.
Let enter Service Mode;
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Board Output Test
While in Service Mode, pressing the Delicates key will begin the Board Output Test. This test turns on a
specified output after a key press. (Pressing the Delicates key again cancels the test.) All outputs
will be turned off after five (5) minutes.
Now Press the Colors / Jeans key this should lock the Left and Right Lid Locks….. did it?
If the lid locked now press the Extra Rinse Key and this should Unlock the Left and Right Lid Locks….. did it?
Let me know and we will go from there. I’m trying to get a feel for what Control Board functionality you have……Rich
Apr 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The locked light is on but I am able to open the lid. It will not start
Hello barbarafreel,
Your machine type is a FAV6800A correct? If so I would try to recycle 120VAC power to the machine. Pull the washer power cord for 30 seconds then repower backup. Do you still have the Lid Lock LED lit? If so further trouble shooting is required. I would next have you go into Service Mode. Once in Service Mode we need to go Board Output Test on page 16 of the Service Manual I will summarize below.
Here is the FAV6800A/FAV9800A Service Manual for your machine. Follow all safety warnings when working on the machine.
Let’s see if you can get into Service Mode, from the Service Manual slightly modified;
Enter Service Mode by pressing and holding the Enviro Plus and Spin Only keys simultaneously for three seconds or the display reads “00”
Now look at page 16 of the service manual let’s see if you can with the Board Output Test function unlock and lock the Left and Right Lid Locks.
Now press the Delicates key.
The LED display should show ot and the Quick Wash led will be lit.
The Left and Right Lid Locks will lock.
Now press the Extra Rinse key pad.
A few seconds should elapse and the Whites led will go lit for a short duration then off and in a few seconds the Lid Locks should unlock. Do the Lid Locks unlock?
Now press the Colors / Jeans key pad again.
Do the Lid Locks lock?
Let me know what action took place and we will go from there.
You can get out of Service Mode by pressing Enviro Plus and Spin Only keys simultaneously or press the Off key.
What I suspect is one of the lid lock is not releasing completely which moves a slide switch in the lid lock to signal the control board that the Lid is Unlocked and the Lid is Locked.
If you still have the issue I would release the washer top form the base and unplug the Right Lid Lock and see if that right lid lock is signaling incorrectly and possibly causing the issue. The Service Manual will show you how to release the washer top from the base. The left lid lock because of its dual signaling function “the Lid is Open/the Lid is Closed” and “the Lid is Locked/the Lid is Unlocked” can’t simply be unplugged. If you pull the Left Hand Lid Lock plug you will show a OP or OD error from the Control Board. If you are up for the troubleshooting I will help you proceed further.
Only the Left Lid Lock assembly needs to be plugged in for the washer to work as designed. I removed my Right Lid Lock a year ago and would never spend the money to replace it my choice.
Dec 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
