Question about Trisonic New Waterproof Torch Light Flashlight Sporting Camping (Trisonic)
What globe for replacement and where to buy them
I need a replacement bulb for a Energizer torch N2120
  • 1,631 Answers
This may help?
Energizer Lighting Finder
Posted on Jun 10, 2015
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Replacement globe for Energizer N2120
Make model and year of car or truck please.
Sep 28, 2017 | Cars & Trucks
How to change the light globe
you usually unclip the bulbs cover
and unscrew the bulb
screw is a new !!! fridge bulb has to be a specific type of bulb
local diy shop.. or emporium
then clip the cover back in
usual small flat wide clip
perhaps one screw
i think you need a torch to see whats going on
Apr 23, 2015 | Refrigerators
How do i open eveready dolphin torch for battery
You need to twist the black bulb end off in the direction of the arrow labeled open. The best way I found was to place the yellow end between my legs to hold it in place.
Sep 23, 2010 | Camping, Backpacking & Hiking
CAble seems faulty-Is it a magnetic pick up? how can I test it?
The best and safest way (if you don't have a multimeter) is to use a torch battery, 3 pieces of wire and a torch globe. Attach wires to the centre terminal of the globe, & one to the globe base. Now cut the wire attached to the globe base and insert the torch battery between the cut ends.This creates a test circuit with the torch globe, & battery in series.There are now two wire ends free. To test your circuit, touch the two free wire end together. If you have done this right. the torch globe will light. To use your tester, touch one wire end to a pin on your shaver wall plug, touch the other wire to a hole in the shave end of shaver cable.If the globe does not light, try the other hole. If it still doesn't light, touch your tester wires together to test it's still working ok. Test the cable again, if no light, you have a broken power cable.
NOTES:
1. For this operation the razor and cable are NOT CONNECTED to the power outlet
2. Use insulated wire and solder them to the torch globe if you can, otherwise use a cheap globe holder from Tandy
May 01, 2010 | Braun 4775 Electric Shaver
Trisonic New Waterproof Torch Light Flashlight Sporting Camping (Trisonic) Logo
391 people viewed this question
Top Trisonic Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Trisonic Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
