Question about Honda Electrical Supplies
Where is 10A fuse holder on honda ex5500 generator exactly located?
  • 682 Answers
Usually on the power board under a black grub screw which you should be able to undo by hand.
Posted on Apr 22, 2015
Have continually to increase speed to maintain voltage
Check the idle-stop screw. They tend to back out, causing the generator to slow down and not maintain regulation
Oct 17, 2014 | Honda Ex5500 Generator Solenoid Stay...
Need to locate Fuse for Horn; interior lights Fuse Box Cover
On this model, the fuse block is located below the left side of the instrument panel, in front of the driver.
The Horn/Interior light fuse is usually the 10A one.
Cheers,
Nov 12, 2009 | 1993 Honda Civic 4 Door
What do the symbols on the fuse guide stand for?
Fuse Locations & Functions
1. Washer nozzle heaters, glove compartment light (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, A/C, steering wheel module (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A)
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield washer pump, windshield wiper motor (20A).
25. Fresh air blower, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A). (if equipped)
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A)
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A)
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A). (if equipped)
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (w/ power windows), Trunk light, fuel door, Trunk lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A). (if equipped)
Fuse arrangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A). Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A).
Oct 14, 2009 | 2002 Volkswagen Jetta TDI
PEAVEY CS 800S WHERE IS THE FUSE LOCATED? WHAT DOES IT LOOK LIKE?
There are many variants of this amp depending upon its age. The fuse will be a ceramic one that should be solid white and be around 10A or more. This will be about 1-1/4" long and located inside the amp. Remove the top cover for access. It will be in a fuse holder. Please make sure that the unit is unplugged before opening.
Dan
Jul 05, 2009 | Sony STR-DE595 5-Channel Amplifier
Back-up lights is no work
Fuse no. 9 (10A) in the driver's kick panel fuse box located on the driver's sidewall below the instrument panel just in front of driver's door.
Apr 06, 2009 | 2000 Honda Odyssey
2001 Hyundai XG300 Fuse Diagram
Here is the fuse arrangement...you can see there are usually some spares if they are there.
This should answer your question.
If it helps please rate my answers.
You can do it.
Brett
Mar 19, 2009 | 2001 Hyundai XG300
Electrical Supplies Logo
63 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
