Question about Treadmill Doctor Horizon 2.1T Upper Control Board
Does anyone know where i can get a a upper control board or have it repaired for a horizon 2.1t treadmill
My Horizon T91 threadmill is moving slower than normal. I checked both belts and there is no slippage.I opened the cover for control board, a red LED on in the lower part of the board.How can I fix?
Can be the motor or the motor control board faulty. You have to check the motor brush if it's OK the you should go for a new Motor control board.
if you wish to get some more details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Sep 26, 2016 | Horizon Exercise & Fitness
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Stuck in up position. Bought a new incline more and if it goes above 5, it will keep climbing and won't come down.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Feb 24, 2016 | Horizon T61 Treadmill
Where can I buy motor control board for horizon treadmill T101
just run in the open air, it's much better to experience real life
Jan 06, 2015 | Horizon Exercise & Fitness
Motor not working
Unless you know how to use a multimeter I suggest calling a treadmill repairer . Home Treadmill Repairs Brisbane Brisbane Leading Treadmill and Fitness...
Sep 23, 2014 | Horizon LS760T Motor Control Board
Horizon Paragon treadmill won't work.
You can try to have someone repair the board. However the cost of the repair may meet or exceed the cost of that OEM PCB for $200. Why? Because any reputable technician will need to inspect EVERY component on the PCB, which could take hours of component research and bench testing. A lot of the bits on the picture you supplied are very generic-easy to find components: voltage regulators, capacitors, resistors, etc.
"one of the boards that a component is missing and another capacitor has burn damage". Capacitor damage is bad mojo. The other issue you'll run into is if one of the caps blew; What else was damaged in the process.
I recomend you purchase the board from the manufacturer. Do you have the ability to transport the treadmill to the dealer and have them install the new, replacement part? If so, have them do the repair so if an issue arises in the future regarding this new part, they will be liable. GOOD LUCK!
You can also try here: fitnessrepairparts.com They may be able to order the part for less or possibly have a better answer.
Jan 07, 2014 | Horizon Treadmill Paragon 308
Omega 3 treadmill - Does anyone know what might be wrong with my tread mill? its showing 500 on the screen and is not starting.
replace the old batteries (if your system have batteries, clean the contacts batteries) put a new ones.
2) adjust the REED swtich see the diagram attached.
3)tight the ribbon cables inside from display board and clean it. tight and clean the upper and lower connector. and try again.
God bless you64554154-b7bd-4100-8a70-779a1727ba63.gif5b2cf7d6-545e-4e9e-80cd-605d4c8ca29d.gif
Oct 16, 2013 | Horizon Exercise & Fitness
Horizon t202 treadmill makes a constant beeping with the word "connection" displayed on dash board.
1) adjust the REED switch see the diagram attached. Clean it+ 2)test for open or faulty 3) tight the connector very well.
2) tight the upper and lower connectors very well and clean it.
3) inside from console tight the ribbon cable and clean it
Sep 02, 2013 | Horizon T202 Treadmill
Incline - Button not working, and also Stop Button not pausing
RUN the software calibration INMEDIATELY, for diagnose, troubleshooting and fix it.
sincerely. God bless you
Apr 19, 2012 | Horizon Quantum II Upper Control Board
Horizon Model 3.2E LCD showing MILE EP 5101
THis is a reboot error. The upper control board is not loading properly. It might flash temporarily but If it stays on the upper control board will need to be replaced.
www.twincityrepair.com
Feb 24, 2009 | Horizon Exercise & Fitness
Treadmill Doctor Horizon 2.1T Upper Control Board Logo
48 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
