Question about Chrysler 2001 PT Cruiser Limited
ELECTRIC DOOR LOCKS CYCLE UP AND DOWN (CHATTER) KEY ON OR OFF CAR MOVING OR STILL
  • 83 Answers
Sounds like a bad ground check your battery posts for being tight
Posted on Apr 22, 2015
Door locks cycling and windows open
dear .if you use key to open ,then you hold key it will open all doors locks and windows ,so , insert key again then move little try to close and hold ,check if key is move smoothly, this case need to replace driver door key cylinder
Dec 18, 2013 | Skoda Fabia Cars & Trucks
Door lock was pushed down and now lock wont come up and door wont open
I will have to get back to you on mine is same just have not had time to look under door panel yet sorry
Mar 01, 2013 | 1995 Ford Explorer
Interior light / electric locks chattering with no key in switch
Yes, you are missing something. The days of removing the battery cable ended with Generators. An Alternator will self destruct if you do that. Be certain to remove it and get it bench tested. Usually kills diodes and often regulator.
the doors clicking sounds like a problem in the door lock circuit, often in the door jamb. If you inspect and find broken wires in the door jamb, do not repair there, you need to replace the entire length. All repairs fail quickly. The wired need to be new and flexible.
On the no start with new battery, be sure to test the neutral safety switch.
Mar 11, 2010 | 1997 Buick Skylark
Neither of our remotes would unlock our doors on our 2003 Silverado Z71 the other day. So we tried by unlocking it with the key. That did'nt work either. Finally, we put the key in the lock and waited for...
TRY Relearning the remotes. to do this get in vehicle with doors closed hold the unlock button down on drivers door while you cut key on and off two or three times you should hear locks cycle and horn chirp. let go of unlock button and hold both lock and unlock button down on one key fob for 15 seconds or so you will see locks cycle move to next remote and do same. then cut key on to exit learn mode. as far as door not unlocking with key this is a problem with lock cylinder most likely.
Feb 16, 2010 | 2003 Chevrolet Silverado 1500
Doors will not lock or unlock. Where are the fuses?
The answer was sent to FixYa by rstelter.
The initial indication of the door problem was a chattering noise when a cleaning cycle was initiated. The cleaning cycle was then aborted and the door remained locked.
Here is the fix.
I restarted the cleaning cycle and when a chatter began I 'jiggled' the door until it opened. I removed the door lock mechanism (4 screws and two connectors) and found that the motor driven cam actuator cycle stopped in the locked position, a high point on the cam. I could not rotate the mechanism because of motor gearing, so I used a drill to remove the rivet heads from the motor mount, which also opens the motor.
The top half of the motor contains the motor and a small transfer gear. The bottom half attaches to the cam through gearing. I rotated the cam drive to the full open position and rotated the gearing to match. I reassembled the motor by attaching it with two 1-1/4" x 1/8" screws and lock nuts. After reassembly the oven works as new.
The main cam bearing is a shallow raised section of plastic riding in a hole in the thin steel frame of the mechanism, and the edge of the bearing is rounded. I did not inspect closely, but I believe there is a potential for binding, which may have stalled the motor in the locked position. Jiggling the door while the mechanism chattered may have relieved the binding enough to release the door.
I was quoted $129.00 just to have an Amana technician look at the problem in 'about a week'. I'm sure they would have replaced the latch with a new assembly (another week and another visit).
Dec 16, 2009 | Amana AEW4630DD Electric Double Oven
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Cleaning over but lock light will not goff and i can not open my oven
May 20, 2009 | GE JKP15 Electric Single Oven
Door locked after shutting down cleaning cycle earlier than
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ford Escort 1998 central locking
Are you talking about the key cylinder or the electric lock button? If you are talking about the key,you need to remove the door panel and watch the lock rod move up and down. There is a plastic clip that pops open or breaks from age. If you are talking about the electric lock, will the passenger door lock move when you press the lock button on the drivers door? Does the passenger door make a grunt noise when trying to lock/unlock?
Aug 25, 2008 | 1998 Ford Escort
Chrysler 2001 PT Cruiser Limited Logo
46 people viewed this question
Top Chrysler Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Lawrence Oravetz
Are you a Chrysler Heating and Cooling Expert? Answer questions, earn points and help others
