Question about Kenwood Kmix Hm792 Hand Mixer, Almond Cream
Looking for a service manual to show how the mixer comes apart so i can replace a damaged mains cable
  • Mark De Keyser
    Mark De Keyser Mar 05, 2016
    Did you get any answers? I've got the same problem.
    New Friend:
Have you managed to replace the cable as I have the same problem? Thanks
Posted on May 19, 2015
My Kitchen Aid Aritsan was a gift bought in the US. We live in Zambia/Africa (using 240v electricity). One day there was a loud pop at the plug and a slight smokey smell. Its never worked since
I will assume that you were not using a step-down transformer (240 to 120 volts).
So what may have happened?
1. The phase board burned out.
2. The stator burned out.
3. The armature burned out.
4. The line cord and/or plug failed.
It could be one, all, or any combination of these things.
A solution is to simply convert the mixer to 240 volts. This can be done by replacing all four items above with the 240 volt versions.
If I were doing this here in the U.S., Ebay would be my source for the parts.
You can find a Service Manual which covers your model (even though it may net say so) and shows how it comes apart at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 26, 2017 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchenaid professional blade stops turning when meets resistance
Carol, if the beater stops turning under a load you are looking at gear problems. Depending on what model you have will depend on what gears need to be replaced. Most professional models have all metal gearing inside and must be taken apart and inspected to determine which part is bad, usually it is a combination of a few different gears.
If you can get the model number off of the base of the mixer then we can look up the correct parts and get you a service manual for the mixer as well.
KitchenAid Stand Mixer Parts Diagrams Service Manual
-Colleen @ Mending Shed
May 23, 2015 | KitchenAid Food Mixers
The power take off for accessories doesn't work
That's a bit of a task to sort out. If you aren't up for a full strip down and clean up followed by new gears and repack with grease then contact Kitchen Aid for a local repairer. You will be up for a couple of gears and maybe even the top housing if the bush for the accessory drive gear is wrecked. If you need "how to" help then get back to me for step by step.
Apr 04, 2015 | KitchenAid K45SS Classic Stand Mixer
Motor clicks every turn
The clicking is probably a small nick in one of the gears, even the smallest chip can cause alot of noise or make the mixer click. Is the beater shaft still turning when you have a load in the mixer (bowl is full)
Or is it just clicking?
If the beater stops turning it is going to be caused by stripped gears, however if it is just clicking this would indicate just a nick in the gear. Either way I would recommend opening the mixer and replacing the damaged gear/gears.
Your mixer is considered a 5 Quart Professional, which means it has the same parts as a KitchenAid 6 quart mixer. The first thing you will want to do is take the mixer apart and disassemble the gearing. You will want to clean off the gears with paper towels and wd-40. Carefully inspect each gear once clean and replace damaged gears.
In the professional mixers when a gear strips you need to replace the grease and housing gasket, this is because the gears are all metal and there may be metal shavings in the grease which could cause the gears to strip again.
The most common gear to go bad in the Professional series mixers is the Worm Follower Gear (9706529). Here is a link to that gear on our website: http://www.mendingshed.com/wormfollower.html
Also, here is a link to the service manual for the mixer, this will aid you in taking the mixer apart and putting it back together correctly. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
We are one of KitchenAid's largest service centers within the US, and all parts we sell are genuine KitchenAid products. All parts are available at our website, www.mendingshed.com
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 06, 2013 | KitchenAid New Professional 5.5 QT...
Oil leaks out when tip up .around
KitchenAid uses a vegetable based grease inside of their mixers, it is a food safe grease. Because of this if you do not use your mixer often and over time the grease inside the mixer can begin to break down, and an oil will leak from the mixer.
What you will need to do is take the mixer apart, clean out the old grease and replace it with new KitchenAid grease, it is also recommended that you replace the gearbox gasket.
We are one of KitchenAid's largest service centers in the US, everything we sell is Genuine KitchenAid replacement parts.
Here is a link to the grease on our website: http://www.mendingshed.com/kagrease.html
And a link to the gearbox gasket: http://www.mendingshed.com/mixergasket.html
Also to aid you in the repair here is a link to the KitchenAid service manual for your mixer. this will show you how to take the mixer apart, replace the grease, and reassemble the mixer. http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 30, 2013 | KitchenAid K45SS Classic Stand Mixer
Kp2671 stops and starts
It is not going to be a problem with the motor. It is going to be a chipped/damaged gear, a bent planetary center shaft pin, or possibly the planetary itself.
The first thing you need to do is take the mixer apart. You are going to have to clean of all of the gears and inspect them very closely. I recommend using paper towels and wd-40. If there is any damage, the gear will need to be replaced, in some cases the pin that sits between the worm follower gear and bevel gear can become bent, if it is, it also needs to be replaced. If all of the gears, bearings, and the pin are in perfect shape inspect your planetary assembly. In some cases the center shaft, which is pressed into the planetary can become loose, so it will still spin under no load, but as soon as you put something in the bowl it stops spinning.
Here is a link to the KitchenAid service manual. This will walk you through how to take the mixer apart, and put it back together: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Please let me know if you have any questions, or need help with the repair.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 15, 2013 | KitchenAid KSM103 Professional 5 Series...
My dualit hand mixer has become noisy as if something is loose inside. Can I take it apart to have a look.
There is 2 screws if you look at the bottom, where the cable is wind. you can see
them through the winding wheel. I had a completly dead machine, by removing these screws i could replace the cable and my machine works again :-)
Jul 03, 2010 | Dualit 88407 300 Watts Hand Mixer
I an looking for the intructions on my Kitchen Aid mixer. It's 250 watt, 10 speed. I cannot wait to use it!
Hi. Goto kitchenaid.com. Click on the Customer Care button, click on find manuals, in the search window, enter k45sswh. this page will show the operating manual and farther down the page the parts manual. Download both these files.
Go to mendingshed.com and locate their FREE kitchenaid service manual and download it. This manual will greatly assist you or a repair person should your mixer ever need repair.
A word of caution...Do not overload the mixer with too much bread or cookie dough or it will cause damage to the transmission. Use the recommended capacities found in the manual.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 06, 2009 | KitchenAid K45SS Classic Stand Mixer
Disassembling the mixer
does the plug run through the base or the back of the unit?
Jun 10, 2007 | KitchenAid K5SS Heavy Duty Commercial...
Kenwood Kmix Hm792 Hand Mixer, Almond Cream Logo
453 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
