Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Changed belt , it broke again not sure why - Hoover U5753-900 WindTunnel Bagless Upright Vacuum
    Master:
  • Hoover Master
  • 789 Answers
Hey, this is Jim with Crucial Vacuum,
More than likely if your vacuums belt keeps breaking its due to your vacuums brush roll sticking, causing a build up of friction and strain on the belt.
Try removing the brush roll and clean off any noticeable debris such as hair, or carper fibers. After putting the brush roll back into place turn it manually a few times to make sure it can move with ease.
We do sell a variety of vacuum parts and accessories including Hoover Windtunnel belts. We can offer free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Hoover+windtunnel+belt&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Posted on Apr 23, 2015
    Top Expert:
  • Hoover Master
  • 45,295 Answers
Gotta make sure both ends of brush bar are clean and turn freely
Posted on Apr 22, 2015
When we changed the belt the new belt broke right away and the brush roller wouldn't spin. My husband cleaned off the roller and got it moving slowly again, but when we went to re-attach everythin
the thing you call wheels are actually called roller bearings that fit at both ends of the brush-roll there probably seized up you can get a new brush-roll with bearings from the link below.
http://dirtdevil.com/parts/category/brushrolls-uprights/
Oct 30, 2012 | Dirt Devil Breeze Bagged Upright
I just bought a new belt, put it on, took two swipes, smelled burnt rubber again. My new belt broke. Why?
The beater bar is probably not turning. It get's jammed up with hair and strings and Christmas icicles and anything else on the floor. Taking the bar out and cutting all the stuff off is the easiest way to clear it. Make sure it turns freely before you hook the belt to it again and watch it when you turn it on to see if it's turning.
Sep 15, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
The belt keeps breaking lately. I've had the
Before putting on the new belt make sure the brush turns freely and nothing is wraped around the bearing ends, if it is not turning free and is clean try a little grease or vasaline on the bearing ends. dont get any on the belt though. check the motor shaft also it should be clean and no residue from the old belts on it. it can be cleaned with rubbing alcohol and a rag, if really caked try a scotch pad .
Oct 24, 2009 | Kenmore Vacuums
My enviro vac is being stubborn
First , spin the brush roll by hand and see if it spins freely. Then remove it.
CLEAN OUT ANY HAIR OR THREAD UNDER THE CAPS Inspect the end caps , if one is melted you will need to replace the cap if available or the entire brush roll assembly.
The "metal piece" is the motor shaft. Clean any burned rubber of with fine wet dry sand paper, then install a fresh belt, using the brush for leverage to stretch the belt into place. Rotate the brush again to be sure it is not binding and that the belt is not pinched anywhere.
Buy 2 belts and keep your spare inside the hood of the vac.
Sep 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Metal Spring in Belt area?
Yes the metal spring is used to pivot one of the rollers in that area.
You would need to take it apart one more time and check to see if any of the roller travel up or down while you press it with your fingers. look to the edge on either side for a place to attach the end of a spring. then a place on the chassis to add the other end of the spring. Then redo the belt.
May 24, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
I cant get the power brush to work is there a reset button? the vacuum is only 2 months old dirt devil 12amp bagless featherlite
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Apr 06, 2009 | Dirt Devil M085850 Featherlite Bagless...
The belt broke on my my SHARK Model V15Z and Euro Pro hasn't responded to my request for a new belt w/ directions as how to effect repairs.
Well it's actually not so bad once you realize where they hid the screws. Gently pull outwards on either side of the housing that surrounds the brush and vacuum.There are no screws for this piece it simply snaps off and on. Once this piece is removed you'll see two phillips type screws on the side where the removable hose attaches. Remove the two screws and pull off the molded section they keep in place. The brush will now come off revealing the rotor that the belts slips over. The belt is placed over the rotor and the brush cylinder in a figure eight. Reassemble and your ready to go. Now if Shark will only help customers locate a replacement belt you may find this info useful.....
Feb 28, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Belts keep breaking
Check the brush roll ends to see if they have melted or frozen. They should turn freely, part #361869-1. Make sure the belt isn't being pinched somewhere.
Apr 15, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Belts
Recently received a kirby from mother in law and don't how to change the belts
Dec 15, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
64 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
