Question about Sunbeam Grilling
Does the Sunbeam digital probe thermometer go up to 225 C
    Top Expert:
  • Sunbeam Master
  • 51,186 Answers
The temp range should be in the instructions
Posted on Apr 22, 2015
The exhaust smoke at the top vent of my char broil 30" digital electric smoker reads 245°, but my panelis set at 225°. Can i recalibrate temp settings
Most smoker manufacturers consider a swing of 20 degrees either way acceptably within range, so there's not necessarily a problem there. Remember that your smoker will measure differently depending on where the temp probe is. Heat rises, so it makes sense that it may be hotter at the top, especially if the ambient temperature isn't too cold. Put a cheap oven thermometer on your rack and use that to accurately read the temp where your meat will be.
Feb 18, 2018 | Grilling
How do you use a cooking thermometer to cook pork properly so that it is not raw?
Check out this YouTube video that shows you how to cook pork with a thermometer;
http://www.youtube.com/watch?v=99LW86jQXDs
Feb 14, 2013 | Home
What are digital probe thermometers? Are they used for cooking meat?
yes - digital probe thermometers are very good for testing whether meat is cooked. The thin sensor is inserted into the fattest part of the meat. A wire then runs from the sensor out of the oven door, so that you can keep an eye on the temperature without having to keep taking it out the oven.
Feb 14, 2013 | Home
How long and what temp should you smoke a chicken for in an electric smoker?
I do a considerable amount of smoking and I cook my whole chicken till I reach an internal temp of 170 in the thigh or breast with a digital thermometer. It can take 3 hours or 5 depending on the chicken. Best to use a digital probe type thermometer for safety. I cook all my smoked meats at 225-250. I hope this helps.
Nov 07, 2010 | Grilling
I have a polder digital thermometer with two probes--but I didn't get instructions with them.. Can I insert the probe in the oven with the meat cooking or use only with the meat out of the oven to test it...
Timer is not identified for certain.
1) Some Polder timers have in-oven thermometer, and others say not to use thermometer inside oven.
2) The 12453 dual-sensor says inside-oven is ok
3) The 894 dual sensor says inside-oven is ok
4) TM360 dual probe says inside-over is ok
Polder timer manuals appear on following link:
http://www.polder.com/productinfo.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 30, 2010 | Polder Triple Digital Timer Model 891-90
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    Smoker h20 deluxe
    I'm a smoker expert having entered in competitions. Thermometers built into the lid are inaccurate because you want to measure the temperature at the same level the meat is at. Heat will rise and will give you a false reading at the top of the lid. Get a digital thermometer that has a cable and a probe on the end. Cut a small potato in half and stick the probe through it so the point exits the potato and is balanced when it sits on the grill. Then run the cable outside to your thermometer. Shade the thermometer from bright sunlight. If you don't want to do this you can simply get a regular thermometer that will measure at least to 225 or more. Stick the thermometer in the top vent of the smoker or if there is no vent just drill a small hole in the lid. Put the thermometer through the vent or hole in the lid and add 10-15 degrees to allow for heat buildup. Example 240 degree thermometer temp will be about 225 at meat level. You may have to experiment with these readings. Happy smoking! Go to my favorite website for smoking.....Google search " Virtual Bullet" and you should be at the Weber Bullet site. Hank
    May 10, 2010 | Char-Broil Deluxe Charcoal H2O Smoker
    I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
    I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
    Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
    I have the same problem. The problem is the probe went bad. I had a friend with another sumbeam digital probe (the mavrick) put that probe into mine and the temperature reading was working properly. So, now I am looking for a replacement probe. but looks like I will have to just buy another digital meat probe.
    Aug 16, 2008 | Sunbeam 4214 Iron
    Grilling Logo
    88 people viewed this question
    Top Sunbeam Grilling Experts
    Gil Shultz
    David White
    Steve Pack
    Steve Pack
    Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
