Question about Singer Sewing Machines
Singer 111w55 the industrial machine tred to shorten the stitches but want change thread stitch length. now it will not pick up bobbin thread.
  • Singer Master
  • 9,272 Answers
I am not familiar with the machine, but did find this online. Maybe you'll find some help there. One suggestion is to oil...
http://www.upholster.com/upholstery-forum/index.php?action=printpage;topic=10841.0
Posted on Apr 26, 2015
SewExpress
  • 41 Answers
SOURCE: Picking up the bobbin thread
A few suggestions:
  1. Rethread top of machine from scratch with the presser foot raised, i.e. remove thread completely from all thread guides & paths and start from scratch, making sure thread is securely seated between tension disks. Once the needle is re-threaded, lower the presser foot and give the tail end of the thread a tug to make sure there's tension on it.
  2. Make sure the bobbin is turning the correct direction for your machine - and that the thread tail is under the tension plate or bobbin tension guide (depending on machine).
  3. Blow out any fuzz.
  4. Insert a new needle, making sure needle is pushed all the way up.
  5. Oil machine (in locations recommended in your owner's manual).
If the basic cleaning and re-threading (above) don't help, your machine(s) may be out of time or have another mechanical issue that will require a repair technician. We recommend a tech trained on your specific brands - they'll be better trained and able to get any repair parts that may be needed.
Hope this helps narrow down your stitching problems.
Happy sewing,
Kim & Linnette
Posted on Jun 27, 2008
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
SOURCE: my singer athena 2000 won't
Yes, the hook timing is off. You need to either take it to a service repair center, or do the timing yourself. If you're mechanically inclined, go to youtube and look for a video by Nilsandkatrina about how to repair your sewing machine. He gives a very good example.
Posted on Nov 29, 2011
Singer 7442 won't stitch at all. It picks up the bobbin thread nicely, but after that won't stitch at all. Any suggestions?
Sound like one or the other of the threads is stuck. Completely un- thread your machine and remove the bobbin. See if the needle moves freely with the machine unthreaded. If it does, carefully rethread the machine and reinsert the bobbin, making sure the bobbin thread is feeding the correct direction. Let us know what happens.
Oct 23, 2016 | Singer 7442 Mechanical Sewing Machine
My stitch length is tiny and will not change
When selecting a stich, there's a button with a triangle with one edge pointing down. There you can select Needle Position and Stitch Length. --PDF manual, page 23
The thread tension has no influence on the stitch length. It just adjusts, where needle thread and bobbin thread 'meet' inside the fabric. A too high tension means, the bobbin thread is pulled trough the fabric and can be seen on the upper (needle) side. A too low tension means, the bobbin thread is not pulled through the fabric and you can see the needle thread on the bobbin side.
Jul 08, 2014 | Janome Memory Craft 9000 Computerized...
Need to know what the knobs are for
Are you sure that it's a Singer LS-1217? I can't find any model with 1217 on the Singer site.
The Brother LS-1217 manual is available here: http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_top.html?reg=eu&c=eu_ot&lang=en&prod=hf_ls1217euk . The direct link to the English version of the manual is http://download.brother.com/welcome/doch000000/ls12171217b13171417ug01enesfrpt.pdf . There are only a few knobs on most machines. On the front near the needle is the Needle Thread Tension knob. If you use contrasting colors (different top, bobbin and fabric colors), you might see a straight stitch where the top thread is visible on the bottom of the fabric for example. Adjust the tension to get both the top and bobbin threads meeting in the middle of the fabric layers. (Increase the needle thread tension - rotate to a higher number but go in 0.5 increments.)
Then you have near the motor area the stitch width and length knobs. The width is only for zigzag stitches. A long stitch length is good for a temporary seam (like basting in a zipper or hem) before you finish that area. However, the width and length should be adjusted depending on the fabric. A fine fabric needs a smaller stitch, usually. The knob on the right side of the machine is the balance wheel (or hand wheel). This adjusts the needle height so that you can have the needle out of the way while changing the bobbin, for example.
I hope this helps.
(I use the Singer Sewing Book as a reference for tension issues.)
Feb 20, 2013 | Brother LS-1217 Mechanical Sewing Machine
How do you stop stitches bunching up on a Singer Symphonie?
try changing the needle
also try changing the top tension
clean under the needle plate & in the bobbin area for lint or loose threads
Apr 21, 2012 | Singer Sewing Machines
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
How do I shorten the stitch to make a rolled hem? Please help.
For the rolled hem: the needle is in the O2 or right position, the length is 1.5 in the rolled section- you will see this, if you look on the side of the bottom knob- you can decrease this to 1, but you have to stay within the rolled section, the width is 3.5. the stitch selector is on D, the upper looper selector is UP, the blade is engaged and the subsidiary looper is to the right. You can use a decorative thread in the upper looper- Madeira Decor, Superior Threads made for bobbin work, or YLI Pearl Crown Rayon- or use a wooly nylon for excellent coverage and not need to decrease stitch length. I usually don't need to change the length with these threads.
May 21, 2010 | Baby Lock Evolve
I have a Singer 6105 and the thread is birdnesting for the second time in a few weeks. I have cleaned the bobbin area, threaded and rethreaded and changed needles. All to no avail. When this happened a few...
Double check:
Threaded with presser foot up.
Feed dogs are engaged.
Stitch length set at proper length.
Thread is feeding from the bobbin spool in the correct order and through the proper guides.
Problem still there - take the machine and a sample of the stitching back to the repair guy and ask him to check the timing.
When you pick up the machine, take a scrap of fabric and give the machine a thorough test run - threading, bobbin winding, stitching before leaving the shop.
Feb 05, 2010 | Singer Sewing Machines
I inherited an old straight stitch singer sewing machine
If you send me a picture of the machine I can tell you what the model is. Is it an industrial or domestic machine, it sounds like it may be an industrial ?
sewingmachines@gmail.com
Oct 09, 2009 | Sewing Machines
Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Nov 24, 2008 | Singer 3116 Simple
Sewing Machines Logo
81 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
