Question about Singer Sewing Machines
Singer 111w55 could not change thread stitch length. But it will not pick up thread.
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
Mongo32
  • 111 Answers
SOURCE: Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Posted on Jun 11, 2009
SOURCE: top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Posted on Oct 21, 2009
  • 351 Answers
SOURCE: singer overlocker model 14u34b user manual
You can find free manuals to down load from singer ..
http://www.singerco.com/accessories/manuals.html
Please vote !!
Posted on May 14, 2010
Need to know what the knobs are for
Are you sure that it's a Singer LS-1217? I can't find any model with 1217 on the Singer site.
The Brother LS-1217 manual is available here: http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_top.html?reg=eu&c=eu_ot&lang=en&prod=hf_ls1217euk . The direct link to the English version of the manual is http://download.brother.com/welcome/doch000000/ls12171217b13171417ug01enesfrpt.pdf . There are only a few knobs on most machines. On the front near the needle is the Needle Thread Tension knob. If you use contrasting colors (different top, bobbin and fabric colors), you might see a straight stitch where the top thread is visible on the bottom of the fabric for example. Adjust the tension to get both the top and bobbin threads meeting in the middle of the fabric layers. (Increase the needle thread tension - rotate to a higher number but go in 0.5 increments.)
Then you have near the motor area the stitch width and length knobs. The width is only for zigzag stitches. A long stitch length is good for a temporary seam (like basting in a zipper or hem) before you finish that area. However, the width and length should be adjusted depending on the fabric. A fine fabric needs a smaller stitch, usually. The knob on the right side of the machine is the balance wheel (or hand wheel). This adjusts the needle height so that you can have the needle out of the way while changing the bobbin, for example.
I hope this helps.
(I use the Singer Sewing Book as a reference for tension issues.)
Feb 20, 2013 | Brother LS-1217 Mechanical Sewing Machine
How do you stop stitches bunching up on a Singer Symphonie?
try changing the needle
also try changing the top tension
clean under the needle plate & in the bobbin area for lint or loose threads
Apr 21, 2012 | Singer Sewing Machines
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
I have a Singer 6105 and the thread is birdnesting for the second time in a few weeks. I have cleaned the bobbin area, threaded and rethreaded and changed needles. All to no avail. When this happened a few...
Double check:
Threaded with presser foot up.
Feed dogs are engaged.
Stitch length set at proper length.
Thread is feeding from the bobbin spool in the correct order and through the proper guides.
Problem still there - take the machine and a sample of the stitching back to the repair guy and ask him to check the timing.
When you pick up the machine, take a scrap of fabric and give the machine a thorough test run - threading, bobbin winding, stitching before leaving the shop.
Feb 05, 2010 | Singer Sewing Machines
I have a Singer Featherweight 221-1 that won't form a stitch
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Jan 10, 2009 | Singer Featherweight II 117
Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Nov 24, 2008 | Singer 3116 Simple
Sewing Machines Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
