Question about Garden
Why does my 60" Xmark Lazerz Ultracut bog down and kill the engine?
I have checked all the belts and pulleys, and also have taken them off and tried engaging the blade. It still wants to die. Could this be the clutch on back of the motor?
    Sergeant:
  • 462 Answers
Try taking out air filter and run it will blow oil around a bit but see if if it bogs
Posted on Apr 23, 2015
    Sergeant:
    Champion:
  • 253 Answers
I suppose it's possible but, without belts on then i don't think it would do that. It sounds like maybe the safety switch isn't working right. Could have a loose wire, broken wire or bad switch. When you go to engage if the safety switch isn't working right it will kill the motor
Posted on Apr 22, 2015
How can I fix this problem???? Have an XMark LazerZ Airlocking.. will not let gasoline enter tank and Im empty.
Go to an auto store and get a length of narrow diameter hose, push it into the tank but hold it above the level of the gas inside the tank and then fill it, the pipe lets air out as gas goes in.
Jul 27, 2017 | Cars & Trucks
Motor shuts off when blades are engaged xmark zero trurn commerical
some of the switches work in series disconnect the kill switch wire from the engine and try it the work your way back to the switches
May 11, 2012 | Garden
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
WHEN I ENGAGE BLADE MOWER STALLS
Stalling and cutting off could be two different problems so I will address both. If the engine is stalling or being bogged down, you could have a pulley frozen or something jammed that is not allowing the belt to turn and therefore bogs the engine down.
If the engine is cutting off, you could have a safety switch issue that is killing the ignition. You may want to check the seat switch and connector to make sure they are working properly. Hope this gets you in the right direction.
Feb 19, 2011 | Garden
Treadmill seems to start out OK but after maybe 2 minutes suddenly bogs down to about half speed then will stop all together if keep trying to go. If step off the belt after it bogs, it will speed up to...
hi,
check the motor and the motor controlling card. check the motor is it over heating or not. also check the speed sensor beside the motor pulley. clean the speed sensor and refix it. then test again
ok
Jan 01, 2011 | Proform iLog 750 Treadmill
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
Scotts mower kohler command 25 motor bogs when mowing
Hi..my name is Keith..and it sounds like you have a binding somewhere on your mowing deck..i would check all the spindles .. pulleys and blades..and check the deck belt..it could have jumped a belt guard and it running on the outside of it..but just remember it has pulley brakes to slow the pulleys down when you shut it off..so..engage the deck without the engine running and check for the binding..i hope this has helped..if not..please write me back
Jul 14, 2009 | Garden
Engage&disengage not working staling out engine
sounds like a siezed mandral or idler pulley,possibly the belt jumped off and is caught between a pulley and the deck or belt guide
Jun 18, 2009 | Craftsman Garden
1996 Grand AM 3.1L serpentine belt replacement
Try this procedure.
To replace a worn belt, locate the idler or generator pulley.
Loosen the hold-down fastener for the idler or generator pulley.
Pry the idler or generator pulley inward to release the belt tension and remove the belt.
Match the old belt up for size with the new replacement belt.
Observe the belt routing diagram in the engine compartment.
Install the new belt over each of the drive pulleys. Often the manufacturer recommends a sequence for feeding the belt around the pulleys.
Art courtesy of Delmar - Thomson Learning.
Pry out the idler or generator pulley to put tension on the belt.
Install the belt squarely in the grooves of each pulley.
Before adjusting belt tension, check for proper pulley alignment. This is especially critical with serpentine belts. Measure the belt deflection in its longest span. If a belt tension gauge is available, use it and compare the tension to specifications.
If a belt is too tight, wear to bearings for the water pump, alternator, and engine crankshaft can result.
Some late-model Chrysler engines require a torque reading to be taken when tension is applied to the generator drive belt. This is especially important on the longer, multiribbed V-belts.
Pry the idler or generator pulley to adjust the belt to specifications.
Tighten the idler or generator pulley fastener.
Start the engine and check the belt for proper operation.
Any more questions please ask. Good luck.
Jan 24, 2009 | 1996 Pontiac Grand Am
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
