Question about Pool & Spa
I need the shaft and bearings - Pool & Spa
  • 1,631 Answers
Do you mean Shaft SEAL?
and MOTOR Bearings?
You will need to know the make and model of your pump, for the proper shaft seal, since that has to do with matching correctly to the 'Wet End'.
And you will need to know which bearings are in your Motor, to get proper replacement.
Amazon com Pool pump shaft seal
and for for the bearings...
usually two different sizes, one for the front, and another for the rear. It's a 4 digit part number, but the 1st digit is usually a 6, and it's not used when requesting a motor bearing, Why? I don't know?
So 6203 is requested as a 203 bearing. There are 304's, 294's, etc.
Browning Motor Base
Posted on Apr 29, 2015
Can the imput shaft on a 2005 mazda e2000 manual van be removed from the bell housing side or do i have to dismantle the entire gearbox as i need to replace its bearing ?
normally ---no
as the dog teeth for 4th gear hit the large first gear on the counter shaft
if that bearing needs replacing, there will be metal bits in all of the other bearings so a quality repair is a box dismantle and wash out
quality practice recognizes that one bearing failure , all bearings are close to failure as well
however if you can get to a decent bearing puller there is one that on the leg ends there are 1/2 balls formed on the ends
you have to remove the cage and these ends fit in and when turned to fit the puller bridge , lock into the grooves and you can pull the bearing that way
replacing would be by heating the new bearing in oil and sliding it back into place on the shaft while the shaft is in place in the box
after removing the bearing , the shaft can come out but to do so will drop the spigot needle roller bearings into the bottom of the box and it has to back in place as fitting the bearing before installing means that the dog teeth will not fit over the counter shaft gear
Nov 22, 2017 | Mazda Cars & Trucks
Remove pulley from mower deck blade shafts
take belts off, loosen big nut on top of shaft, leave that big nut on the shaft just a few threads then take a hammer and tap on that nut to loosen the shaft from the bearings, take nut off then the shaft should fall out, if your bottom bearing is stuck on the shaft itself its gunna be fun to take that off, but if it didn't get stuck then take a punch and hammer to the bearings go thru the top to get the bottom one and vice versa, your gunna need a hammer for most of it, hope this helps its not that hard
May 20, 2015 | Garden
How do you replace the bearings on the shaft
Shaft bearing replacement on any motor requires that the rotor (the part that spins) assembly be removed from the stator (the non-moving body that contains windings) and the end bells (the motor ends that the bearings are supported within).
Once the rotor assembly is removed, shaft must be pressed out of the bearings. Shops that do this work employ an arbor press as shown below for this work.
This is done best by hanging the entire rotor assembly by the inner race of the bearing. The inner race is the inner ring of the bearing that is pressed on the rotor's shaft. The outer race is the outer ring of the bearing that fits in the end bells. The ball bearings are located between the inner and outer races. If you lack an arbor press to hang the rotor from, you might cut a U shaped slot only slightly wider than the shaft in the edge of a piece of flat steel stock. You could secure the flat steel between two uprights with the rotor hanging in the U slot. Repeated blows to the top of the shaft with a softer metal than shaft - or with a block of wood between the hammer and shaft - should force the shaft downward and eventually free it from the bearing.
By supporting the rotor by the inner race, no undue stress is placed on the ball bearings - and it could be reinstalled again if needed. If you are replacing the bearing, you do not need to be as fussy with supporting by the inner race. You must support by the inner race during removal if you need to reinstall the bearing as the bearing would be damaged if not.
Installing a new bearing or reinstalling the old bearing on the shaft will require the the bearing is supported by the inner race and the rotor be pressed or driven into the inner race. If the shaft is driven or forced into the inner race and support of the bearing is not at the inner race, the balls in the bearing will be damaged and will be noisy, run hot and fail prematurely.
If the bearings are to be pressed into end bells then they should be pressed or driven by the outer race, not the inner race. We're trying to drive or force the part of the bearing that is being held - rather than trying to transfer the pressure or blows through the steel balls that are between the inner and outer races. Use of an old socket, piece of steel pipe, etc. that has the same outside diameter as the outer race often works well to evenly transfer the blows directly to the outer race. Do not try to apply the blows by alternating the energy of the plows all around the race - keep the energy of the blows centered evenly. Use a block of wood to help absorb some of the energy to prevent damage to the bearing or causing pieces of steel from breaking off the pipe, hammer or socket. Always wear safety glasses and gloves!
Mar 13, 2012 | MotorGuide STANDARD MOTOR REPLACEMENT...
My care bearing is goin out
Remove the drive shaft from the truck. Using WD40 or PB blaster lube the bearing shaft and bearing housing. Allow it to soak for 20 minutes. Using a hammer and block of wood tap the bearing with housing off the shaft. Clean the shaft and tap the new bearing on.
Dec 05, 2011 | Dodge Ram Pickup 3500 Cars & Trucks
I need to know how to remove the bearing from the drum. I have split the outer drum but can't get the shaft out of the back of the outer drum? My washing machine is a Hotpoint WT 960
this just takes a bit of mucle and time.
remove rear pulley and then refit screw (without washer) into shaft. screw the whole way in. then using a lump hammer knock shaft out. may take a good bit of hammerin.
knock bearing out then and also unclog the weep hole in bearing housing.
grease the bearing housing and press in new bearing and seal.
if old shaft damaged ( which prob is if hard to knock out) you will need to replace it.
screws holding shaft to drum usually impossible to undo so drill them out using a 8mm bullet bit.
fit new shaft, put some bearing grease on the bearing seal and re-assemble the drum
Oct 19, 2010 | Hotpoint Washing Machines
Pondmaster mdl 24 Series magnetic pump. re: Replacement impeller/magnetic shaft installation Question: What do I need to do to install the impeller ***'y into the pump housing to ALLIGN THE...
The bearing needs to be pressed onto the ceramic shaft before inserting the impeller into the housing. Then it just drops in (while trying to hold on to it the best you can to keep it from slamming in.). New bearings didn't come with the new impeller? If not you will have to carefully pry out the old bearing from inside the housing.
Aug 18, 2010 | Pondmaster Impeller & Magnet for Pond -...
I need a blower assembly for weatherking model#RHCF-100ZK
Go to www.americanhvacparts.com . You can buy bearing and a shaft from any HVAC supply house. They are standard bearings and shaft. Rus
Mar 17, 2010 | Heating & Cooling
1985 M Benz Sd differential s half shafts
first remove the differential half shafts and drive shaft, remove rear cap, loose the bolts on each end bearing,remove the differential assy. then replace bearings
Apr 12, 2009 | 1985 Mercedes-Benz 300
Replace left rear axle seal 1999 ford explorer
Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the differential housing cover (4033).
    1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
    1. Remove the bolts.
    1. Remove the differential housing cover.
Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
  3. Remove the U-washer (4N237).
  4. Push the axle shaft inboard.
  5. Remove the U-washer.
Reinstall the differential pinion shaft.
  1. Install the differential pinion shaft.
  2. Install the differential pinion shaft lock bolt finger-tight.
  3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
    Remove the axle shaft.
Seal Removal
  1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
    NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
6c7eb46.gif Installation
  1. Lubricate the new rear wheel bearing.
    • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
    • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Using the special tools, install the rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. Using the special tools, install the wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Feb 22, 2009 | 1999 Isuzu Rodeo
Rear axle berrings
Tools needed- typical socket and ratchet set, Axle slide hammer, Wiz Wheel type rotary cut off tool, chisel, ball pein hammer, hydraulic press, bech vice
First you must remove the rear wheels, then you must remove the brake capiler and mounting bracket, remove the brake rotor. unbolt 4 nuts on back side of brake dust shield that hold the seal and bearing securly in place. then you must attatch the slide hammer to the axle shaft by using the vehicles lug studs and lug nuts. use the slide hammer to knock the axle shaft out of the housing. it generally takes about 10-15 hard slams before it comes loose. once axle shaft is free to come out remove the slide hammer and pull the shaft from the axle tube. place the axle shaft into a vise and use the cut off wheel to cut off the bearing spacer. cut parralell to shaft until you hear a snap sound once it snaps use the hammer to slide the spacer off the end of the shaft. next you need to cut the bearing off the shaft using a the same technique being careful not the cut the shaft or the seal retainer plate. once the bearing is off then you can slide off the old axle seal. now slide on a new axle seal, axle bearing, and bearing spacer. take assembly to a hydraulic press and press the spacer and bearing onto the shaft until it seats squarely and make sure its all the way down onto the axle shaft. lubricate bearing with gear oil. and install shaft back into axle tube making sure that the recess in the seal retainer plate lines up with the abs sensor wire. tighten all nuts evenly top off gear oil
Dec 27, 2008 | 1999 Jeep Grand Cherokee
Pool & Spa Logo
185 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
