Please call my husband at 7329398056 John Castella about stopping the foreclosure on our home. Penny mac is screwing us over for the last 4 yrs he has all the info
    Top Expert:
  • Washing Mach... Master
  • 52,097 Answers
We do not do that for anyone
Posted on Apr 22, 2015
Will not shut off when plugge in...will still drain fine when I do plug in
How to Fix a Washing Machine Where the Water Won't Stop ...
homeguides.sfgate.com > Foreclosures > Other Foreclosures
1. Turn on the washing machine, and allow it to fill half full of water. ... Turn theshutoff valves on the cold and hot water supply lines clockwise to run off the water running to the machine. ... Remove it and all wiring connected to the terminals.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - When trying to find the the fault Please bear in. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay before looking any further. ... Washing machine will not drain or is noisy on drain. Generally .... As the appliance goes into to rinse it starts filling, then does not stop.
Jan 26, 2016 | Washing Machines
What does "Foreclosure" means?
Foreclosure is a situation in which a homeowner is unable to make principal and/or interest payments on his or her mortgage, so the lender, be it a bank or building society, can seize and sell the property as stipulated in the terms of the mortgage contract.
http://www.investopedia.com/terms/f/foreclosure.asp
Aug 29, 2013 | Finance
When i screw the filter plug back in, the water still leaks, hoover optima wash wmh148df-80
I suspect there is either limescale in the thread of the filter plug OR behind the filter itself and this is stopping the plug from being screwed home. Remove the plug, pull out the filter, clean filter compartment all round, especially at the back AND ensure the plug thread is completely free of limescale ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 15, 2011 | Hoover Washing Machines
Was using our powerwasher,,it;s 3 yrs old..have only used it 4 times...and the water just stopped coming outta the gun...my husband thnks the pump went on it...we have only used it 4 times..
On the round piece that the garden hose screws too there is a filter screen in there. Remove it gently with a screwdriver around the edges and clean the screen then put it back in.
Mar 16, 2011 | Honda Garden
My Bunn coffeemaker is leaking water after it stops brewing and the coffee doesn't seem to get as hot as it once did. It also only gives back 4 cups for a 6 cup brew.
if you unscrew the top there's a rubber seal in there that you might have to replace that causes the leaks. also clean your coffee maker regularly with vinegar.
my husband had to replace the seal in ours 4 times but after owning the same Bunn for 20 yrs it was time for a new one
Jan 18, 2011 | Bunn 10 Cup Home Coffee Brewer
It suddenly stopped working. It is 3 yrs old.
i restore my opperatting sistem and cant access my drivers again
Aug 31, 2009 | Dolphin Maytronics Diagnostic Robot...
Garage door opener chain out of sync with door
There are two white screws on the sides that adjust the limits. Adjust the "down" screw less. You should have to turn the screw 4 full turns for eight inches. After you make this adjustment, test it without the door being hooked up to prevent damage to the door or opener if it tries to close too far.
Feb 27, 2009 | liftmaster Chamberlain Garage Door Opener...
We are renovating our kitchen & last week my husband moved thbe washer. It is taking in water but it then runs straight back out through the outlet hose....please can you help. It is a Hoover washer...
is the hose lower than the tub as this could lead to the water siphoning out due to gravity, the outlet hose standpipe should be at least as high as the top of the drum
Jul 15, 2008 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
