Question about Samsung Heating & Cooling
Samsung Vrf DVM units error codes - Samsung Heating & Cooling
2 Suggested Answers
lpfaff1
  • 11573 Answers
SOURCE: Lg vrf error code ch 79
Error codes below
https://www.lgklimaat.nl/Sitefiles/downloads/LG%20Checkpoint-%20codes/LGCheckpointcodes.pdf
Posted on Jan 27, 2016
H2 error on ODU display
https://www.carrierair.com.au/installer-and-technical-support/fault-codes/
Check the links to talk to a technician or service. I find no easy access to matching a sheet of error codes with your carrier VRF on the web. I encounter codes but the sheets fail to identify the models! Those codes refer to a decrease malfunction which defies interpretation by any but an air conditioning technician. So, the most direct route to your query answer is at the above link.
Jun 16, 2017 | Carrier Heating & Cooling
E6 error blue star vrf
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need anything else air conditioning related don't be afraid to check us out our AC Service and information online.
Sep 03, 2016 | Heating & Cooling
Toshiba vrf h07 error solution
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 21, 2016 | Toshiba Televison & Video
Whats the problem of vrf koppel aircon if P3 appeared in the display
Search online for "error code *** +your make and model".
Jul 17, 2015 | Heating & Cooling
Lg multi v
I didn't see a ch but both 5 and 11 point to high pressure. 5 is a liquid temp sensor short, 11 is high pressure error. Sounds like a bad sensor. Best Wishes!
Aug 17, 2017 | Heating & Cooling
We undertake annual maintenance contract for Sanyo VRF air conditioner at standard charter bank nepal ltd., we have found the AC dose not function as well now. The fault shows as E4 on remote control. Now...
E04Indoor seeing error from outdoor. Qty of i/d units connected are less than qtyset. Check; all i/d units are ON,
reset turn off all units wait 5min power up
Helpful?
Jan 28, 2011 | Heating & Cooling
E000 IS DISPLAYED IN THE MACHINE
E000:
The main thermistor reading does not reach 40ºC 14 sec after the fixing
heater goes ON. (fixing low temperature error).
First you need to try reset the error code and the procedure for that is:
SERVICE MODE entry: MENU and #
If E000 through E004 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and turn
off and then on the power switch to clear the memory: #7 PRINTER>#4
PRINTER RESET>YES=(*).
If the error is still present after clearing, you need to dismantle fixing unit and check with universal voltmeter the lamp, by putting the DVM to buzzer mode and each ends of dvm probes put on ends of lamp, if it buzzs that means that there is connection and lamp is OK, so you need to focuse on thermistors and thermofuses or ... call service.
Hope that helps!
Aug 19, 2010 | Canon iR 1600 Laser Photo Printer
Can you tell me what fault code E2 on a Hotpoint dryer 9344 means please? It seems as if the heater works for a while but then I think it cuts out and I cannot decide whether to call the repairman or...
To my knowledge, on most brands/models, an E2 error code indicates a a "thermistor failure" This could be indicative that the temperature is too high (which I am assuming is not the case) or the temperature sensor is defective, more specifically shorted (the continuity test reads below 500 ohms).You would need a continuity tester (DVM) to verify this. Should you find it useful, the standard resistance measurements are:
  • 60 degrees F. - 15.3K ohms;
  • 70 degrees F. - 11.9K ohms;
  • 80 degrees F. - 9.2K ohms;
  • a reading greater than 50K would indicate an open thermistor and would display error code E1.
This of course would require opening the unit, replacing the aforementioned part (if tested bad), a fair knowledge of electrical/electronic components and circuitry as said, use of a DVM and safe working practices. If you are uncomfortable with w DIY (do-it-yourself, then perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 19, 2008 | Dryers
Heating & Cooling Logo
97 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
