I am trying to program the Hitach SelecSet 700 and I need the generic access code to get into the menu. I had the code once but I didn't write it down.
  • 3,957 Answers
You can download the quick reference manual from here. Perhaps it will have what you are looking for.
http://www.manualslib.com/download/576268/Hitachi-L700-Series.html
Posted on Apr 22, 2015
Testimonial: "Thanks for sending the manual link. I already have the manual. I found the code in an old email. The code is #7 to program and ##7 to remove programming!"
  • ka4iup
    ka4iup Apr 22, 2015
    Glad you got it figured out. Make sure you add those to the manual.
I have an 2008 Hyundai elantra and get code 700& 760 what that mean?
Code 700 is a generic code that means a problem has occured with the transmission control module, and code 760 is for a shift solenoid failure.
The shop would use a repair manual to test the circuit for the shift solenoid. If the solenoid is faulty, it would need to be replaced and the module reset.
Sep 03, 2015 | 2008 Hyundai Elantra
P0 700 and a po 602
602 is a microprocessor and/or a programming issue with the PCM. 700 is a generic code for a transmission problem. This one could be caused by the 602 code. Basically to fix this, you have to have the PCM reprogrammed first, then if the code comes up again, the PCM has to be replaced and programmed to your truck. Then if you still have a transmission code, it will have to be addressed. Shop shops can do this work. Much cheaper than a dealer.
Mar 01, 2015 | 2011 GMC Sierra 2500HD
NEED TO ADD CODE TO URC REMOTE
Try these instructions and see if they work for your genie remote.
First, have your Genie Mini receiver connected and powered on. Next, grab your RC71 remote and simultaneously hold the "MUTE" + "ENTER" buttons until you see a box appear on your TV screen that says "Applying IR/RF Setup. Please Wait" (this appears after about 5 seconds of holding those buttons). Once complete another dialog box will appear and read, "Your remote is now setup for RF." Click "SELECT" to exit that screen. Next, click the "MENU" button, scroll down to "Settings & Help", then click on "Settings", scroll down to and click on "Remote Control", then click "Program Remote". Next you will have two options, either "Program TV" or "Program Audio Device". Click "Program TV", this takes you to a screen where you need to select what BRAND your TV is. After you have selected your TV brand you will have to select the TV Model ( I recommend looking at the sticker on the back of your TV for the accurate Model number or using your current TV remote to find the model number from the menu screen on your TV for fastest and best results). Once the correct model number is selected, AIM your RC71 remote at the TV and it will AUTOMATICALLY program!
Jan 29, 2014 | One For All URC-9910 LCD Remote Control
I can access my security code in Nokia 2700 classic how to solve or how to format
Try this instruction whether it is suit for you or not?1. Menu 2. setting 3. restore all factory 4. Put your security code 12345 if you didn't changed from the company default number. In case if you had changed it than put your security code else if you didn't remember or forget your number than you should go to the nearest Mobile Service Centre for reset.
Thanks for using FixYa All the Best!
Aug 01, 2011 | Nokia Classic 2700 Cell Phone
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Code 700 300m 2004
PO 700 is more a generic code to inform you of the presence of a transmission code or codes.
Dec 04, 2009 | 2003 Chrysler 300M
Blutooth bh-700
Hello, the manual will almost always tell you the default verification code. In this case it's the generic default 0000. If this dosn't work, look at the manual below under 'Pairing'.
Actually here's the manual: http://nds1.nokia.com/phones/files/main_page/Nokia_BH-700_UG_en.pdf
Nov 22, 2009 | Nokia Bluetooth Headset BH-700 for all...
Coding to VCR and DVD
IF not then you should be able to program in Emerson 0591, 0675 for the DVD player
Emerson 0037, 0184, 0000, 0121, 0043, 0209 for the VCR
THe problem arises however, that the vcr and the dvd function buttons are the same, so you can only program one or the other. You need A different remote. I would suggest the 15-2142 made by radioshack. It is the Family 4 in 1 remote, and it has all the functions you need. THis remote is also backlit on some buttons to make it a little easier to see in the dark.
Mar 12, 2008 | Radio Shack (15-2147) Remote Control
I pluged the radio in me car an it says code in before itl work i got it off a friend an he had it workin in his car before i tuck it ou an he said e lost the code he only used the code once an didn n
You need to enter the code using the remote. Try these codes.
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN meNU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
Oct 18, 2007 | Sony CDX-M630 CD Player
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
