How to initiate channel scan? what button do I push?
Not familiar with all remote directions
  • 3,957 Answers
Google search your manufacturer make, model and the word manual. You can download the manual from the search results, and the information you see will be there.
Posted on Apr 22, 2015
Button to scan in channels
The CT-90326 remote was included with several Toshiba televisions, including the 42HL800A. You can't directly scan for channels with a single button on the remote. First make sure that the TV is set to the TV input. (Use the Input button on the remote (top left) or the TV (lowest button on the left side as you face the screen).) Next press Menu (the second lowest button on the TV or the button at the lower left of the Left arrow button). Use the Left or Right arrows to select Setup (with the gear icon) and press OK. Use the Up/Down arrows to select Auto-Tuning and press OK. Use the Up/Down arrows to reach the line to select the type of channels to search for a signal. Then use the Left/Right arrows to select Digital channels, Analog channels or both. Go down another line to set the bandwidth of your broadcasts. Again use the Left/Right arrows to select the correct one. Go down one more line to Start Scan and press OK.
These details are in the manual for your TV. The manual for the 42HL800A is available from Toshiba's product support download page: http://www.mytoshiba.com.au/support/televisions/led-backlit-tv/hl800a/42hl800a/download . The direct link to the manual is http://www.mytoshiba.com.au/file/download/resource/file/19610/toshiba_32av80032%2040lv80026%2032el80032%2042hl800_om%20(au).pdf .
I hope this helps.
Oct 02, 2016 | Toshiba CT-90326 Remote Control
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
How to initial The TV? Problem: Only one channel available when connect a cable right now.
Hello:
It sounds like you need to do a "channel scan". For the LG 26LX1D, you can follow these directions:
  1. Press the "MENU" button on your remote
  2. Use the Up and Down Arrows to select "SETUP"
  3. Press the ">" button
  4. Use the Up and Down Arrows to select "EZ Scan"
  5. Press the "ENTER" button
This will scan all available channels. You can edit the channels by choosing "Channel Edit" in the same menu.
Mar 06, 2011 | LG 26LX1D 26 in. LCD HDTV
SVA television. Have model # EV1703 Remote no
When you say the remote doesn't get the channels I have to assume the channel entry behavior changed. I am not to familiar with this brand but these are the basics for most tv's. If you have not removed the cable input to the tv or unhooked anything before the problem started here are a few thing you could try. Push the menu or setup button on the remote and under the channel or setup option on the tv make sure it is set to Cable and not Air or Antenna. Run the tv through the auto channel search to reprogram the cable channels. This process can take close to 1 hour on some tv's since it has to scan through the digital and analogue tuners. This will allow your tv to add the correct cable channels and remove the unwanted ones. You should be able to enter the channel number or move up and down with the channel buttons on your remote.
Dec 10, 2009 | SVA-USA EV-1703 17 in. LCD Television
How do I unlock channels (pro-2055)
the unlock command is done from the manual mode.
If you scanner is in the scan mode, push the "MANUAL"button to stop the scanning feature.
Next you need to go to the channel you want to unlock. If you are only a few channels away, while in the manual mode, push the up or down arrows to step (one push per channel to be stepped though) to the channel to be unlocked.
A direct method is to enter the channel number on the keypad and then push the "manual" button. The display should show the channel you desire.
If the channel lockout is on, the second line on the display will show "LO+". Push the keypad button marked "L/OUT" once. The "LO+" should change on the display from uppercase to a lowercase "lo+". The channel is now unlocked.
Oct 16, 2009 | Radio Shack Pro-2055 Base Scanner
Pressed the wrong button on the remote
There is a button on the remote labeled "tune" when you push this it will display direct tune on the receiver. You can then enter the channel. It should stay in that mode unless you push the band button again. Hope this helps
Aug 06, 2009 | Sirius STILETTO 100 MP3 Player
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
32" Sony Wega -- initial set-up menu constantly on
Came across this because I was having the same problem. I was getting the menu immediately. It started with the remotes not working with the TV, so I unplugged it. Afterwards, the initial setup appeared, but couldn't complete. I don't have anything connected to the tuner, everything is on video inputs. Don't know why it wouldn't complete, it would get 20-40 channels into it, and stop, and the "initial setup screen" appeared. I ended up turning off all peripherals, waited about 10 minutes, then running the setup. it finally completed the scan of the tuner channels, and has not appeared since. Perhaps just an accidental solution, but hopefully something in there helps.
Jul 26, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
