Question about Whirlpool LHW0050PQ Front Load Washer
Power button doesn't stay engaged, this is a new problem. I had just don't a load and started the next load and the power button wouldn't stay pushed in and lights go off.
    Problem Solver:
  • 41 Answers
Hi i will say you may need a new power switch but remove the old one and have a good look at it you may be able to fix it
Posted on Apr 22, 2015
Testimonial: "Thank you."
Start button does not activate door lock and will not turn on
It may be a micro switch that is not engaging. Try pushing on the door to see if that solves the problem. If so, put in a spacer to push the switch more.
Jan 24, 2015 | Bosch Nexxt300 WFMC220 Front Load Washer
My Chrysler Sebring 1997 v6 wouldn't start or have
Either the starter is defective or the ground wire is not on tightly!
Jan 14, 2013 | Cars & Trucks
How do i know i need a whole new fuse box
You don't mention the year, make and model of the vehicle so, my answer will be as vague as your question.
A gasoline engine needs four things to run: fuel, spark,compression and combustion.
When you turn the key does the starter engage? If no, check for power at both sides of the fuse when turning the key.. If there is no power at the fuse when turning the key, go to the ignition switch. You have isolated your problem.
If there is power at fuse then, go to the starter relay. If there is power going into and, going out of the relay then, check the starter. You have isolated your problem.
If yes, check for fuel, spark (plugs and wires), compression(block, pistons, rods, Intake and gaskets) and combustion (small scale explosion from compressed fuel and spark, thus pushing piston).
Your problem may be with a passive anti-theft system installed by the manufacturer. I wouldn't know because you didn't mention the year, make and model of the vehicle.
Your problem could be with a collision based fuel shut down system installed by the manufacturer but, I wouldn't know because you didn't mention the year, make and model of the vehicle.
Your problem could be with any number of common issues related to a specific vehicle; issues that may been discussed at length on this very site but, I wouldn't know because you didn't mention the year,make and model of the vehicle.
Oct 25, 2012 | Max American Terminal 30 i Fuses
My RCA T19060GY TV/VCR will not stay on. When I push the power button on the unit itself (I don't have the remote.), the green indicator light comes on for two seconds and I hear to click sounds
the clicking sound is due to the relay is getting turn on but doesn't stay because of bad component in the power supply board or in the main board. you must check first the bridge type diode and FET transistor using an analog or digital tester.
Aug 16, 2012 | RCA Televison & Video
My clutch works sometimes and sometimes it don't. I was driving came to a stop, tried to go it sounded like the clutch popped out of gear or something broke. My car wouldn't go so I got towed. but...
A clutch that's failing doesn't behaves like that - it slowly starts slipping until it fails completely and definitely. If it would break suddenly (like when the pressure plate would snap) the noise and the vibrations it would generate would be unbearable.
No, in your case something is failing inside the transmission/gearbox - most likely in the command forks and their locking pins. The gearbox will have to taken off the car and dismantled to investigate and fix that, and it will be expensive.
Sep 25, 2011 | 1994 Toyota Corolla
I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
I think that's Demo mode.
I got stuck there too.
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 26, 2011 | Aiwa CDC-X204 CD Player
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Whirlpool LHW0050PQ Front Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
