Question about Konica Minolta bizhub Office Equipment & Supplies
Scan job is in waiting - bizhub Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Sir what model machine do you have?
Posted on May 13, 2015
PaperPort states Out-of-Memory and won't scan anything...how to fix?
try clearing the jobs waiting buffer. click on files and see what's still waiting to be printed- clear it if there's nothing important. sometimes pulling the power cord out, wait 15 minutes reset the computer works. try powering down the printer first good luck!
Nov 03, 2013 | Computers & Internet
I have the Lexmark X2670 and a couple days ago I scanned a document. Now I am not able to print anymore, I have items waiting to print when I check the printer, but the printer continues to print out...
Reset your printer by unplugging the power adapter from it(small black box behind the printer where the power cord is attached). Wait for at least 10 seconds before plugging the power adapter back in the printer.
Clear the print queue first before sending another print job. Follow the steps below:
Apr 07, 2011 | Lexmark X2670 All-In-One Printer
I downloaded mx300 software. when i was already scanning a document...it says printing maintenance is still in progress and it cant scan...what to do?
The best option is to simply wait, and reset the scan job; it will occasionally interrupt it if the printer is charging ink or in progress with another job.
Mar 10, 2011 | Canon MX300 Office All-In-One Printer
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
The processing/data light is flashing....what to do??
There is a job waiting to be processed. Need to check status monitor to see what is waiting. If it is not critical you can cancel the job from that same screen.
Because you have an i model copier it must be setup to print and scan also. Someone might have sent a job that could be processed for one reason or another. Look in the bottom right side of touch screen for status monitor and see what details it has.
Hope this helps
TankMurdock
Apr 24, 2009 | Canon imageRunner 2030i Printer
I have a microtek scanmaker 4900 mpdel. I was scanning a page from a book and cancelled the scan. Now, every time I try and scan something the message "no scan jobs checked!" appears and I...
Try this:
  1. In your ScanWizard Advanced Control Panel, click View
  2. Click Scan Job Window / Scan Job Queue
  3. When the window pops up:
    • If any boxes are checked in the Scan Job Window / Queue, uncheck them, and recheck them.
    • If no boxes are checked in the Scan Job Window / Queue, check them.
  4. Close the Scan Job Window / Queue.
You should be able to scan again without any issues.
Dec 19, 2008 | Office Equipment & Supplies
Error 2200
Error 2200 is a Scan Carrier Stall error... Maybe the scan carrier stalled during a scan job. Turn off the printer, wait a few seconds, and then turn on the printer.
Jan 29, 2008 | Dell 962 Photo All-In-One InkJet Printer
Scanner does not scan
Reset the device when it does not respond. If the device does not respond, disconnect and then reconnect the power cord.
  1. At the device or at the electrical outlet, disconnect the power cord or adapter.
  2. Wait approximately ten seconds and then reconnect the power cord.
  3. Wait until the device has completed its cycling process before submitting another job request.
Nov 06, 2007 | Canon PIXMA MP130 All-In-One InkJet...
When scan job is sent a start failure error comes on the display
Don't worry about the clean roller message. It is just a reminder much like your scheduled maintenance light that appears in your car.
Start Failure can occur for a number of reasons. When you get a start failure message close your scanning software and reopen it. Sometimes your connection may degrade if left idle. If that doesn't work shut down the scanner and pc. Turn on the scanner and wait until it is fully initialized before turning on the PC. These steps have resolved that problem for me. Lacking a manual, I just try things. Good Luck
May 07, 2007 | Kodak Digital Science 2500D Path-Through...
41 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
