Question about IBM Correcting Selectric II
When I hit the spacebar it reads one "hit" as 7 or 8 spaces every time, how can i correct this?
Also when I get to the end of the page the scroll wheel does not automatically revert back to a marginal position, i have to hit "enter" and move it back by hand. any thoughts? your help is appreciated.
    Problem Solver:
  • 12 Answers
Here's a basic video on how to open it up and take a peek at the mechanism:
https://www.youtube.com/watch?v=uB3sM2cA6Wk
Here's a full blown repair manual in pdf format:
http://bitsavers.trailing-edge.com/pdf/ibm/typewriter/selectric/Troubleshooting_The_IBM_Selectric_Typewriter.pdf
Posted on Apr 22, 2015
    New Friend:
  • 41 Answers
Hi i will look for any dirt, dust or any small pieces inside also make sure nothing is lose
in some chases a good clean can sort a lot of problems
Testimonial: "there has to be something specific thats wrong with it, i don't think a cleaning will suffice. is there a manual you can refer me to so i can take a look at the hardware itself?"
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
Why is my spacebar scrolling at times?
Hi Norman,
The keyboard acts as a text tool when you've clicked in a text box and as a scroll button when you click outside a text box on a web page. Since you say you have a laptop, I'm guessing that you click the text box to type, start typing, and while you're typing, your palm touches the mouse track pad just enough to register as a click while the mouse cursor is elsewhere on the page. I'm not sure if there's a setting to make the space bar stop scrolling altogether but there are settings to make the track pad less sensitive if your track pad manufacturer supports it. For WIndows 7, go to Control Panel>Hardware and Sound and click Mouse under Devices and Printers. As mine is a Synaptics device, this window gives me an extra tab with extra settings. It may be worth checking out yours to see if you can turn down the sensitivity. Some laptops also have a handy key combination to turn the track pad on and off. Mines Function F7, but it's probably manufacturer specific. Check your laptop documentation to see if this might be an option.
May 08, 2014 | ASUS Computers & Internet
Spacebar disfunctional
change out the keyboard or turn machine upside down and shake it gently. You may have something stuck under it
Apr 27, 2014 | Microsoft Windows 7 Professional Upgrade...
Space bar keeps going but not pressed
might be dirty, get a can of air, from like home depot, office max, etc. turn off laptop, take out battery, turn upside down and blow the air underneath the spacebar, this should fix your problem. If not you need a new space bar.
Chad
Apr 12, 2013 | Toshiba Satellite Computers & Internet
Problem with spacebar key
I don't quite understand why this would happen after pluggin in a USB mouse - but I've seen it numerous times after a liquid has been spilled on a keyboard.
Sounds like you need to replace the keyboard. Best way to test this is to plug in an external usb keyboard and see if you can type normally on it.
If the laptop keyboard exhibits this behavior, and the external keyboard doesn't - you should replace the laptop keyboard.
Dec 30, 2012 | Dell Computers & Internet
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
When i press spacebar my search results page appears
Keyboard replacement solved the problem. In my case it was a faulty Logitech keyboard. It seems that Spacebar is acting as F3 and Space the same time.
Feb 04, 2010 | Logitech 967437-0403 Keyboard
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 29, 2009 | Swintec 7040 Typewriter
HOW DOES THE SPACE BAR CLIP GET REINSTALLED?
Take the wire piece out of the keyboard and attach it to the space bar by snapping the long horizontal section into the notched moldings you will see along one edge of the underside of the spacebar. Now turn the spacebar back over, orient it with the high side toward you and the lower side toward the other keys, fit the retainer ends into the slots in the keyboard, and push the spacebar center pin back into its hole. The wire is not really a retainer; it is there to transfer to the center pin any pressure applied to either end of the bar.
Mar 07, 2009 | Logitech 967437-0403 Keyboard
Letters typing very slow and repeating
Sounds like your keyboard needs a clean and some new batteries.
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
IBM Correcting Selectric II Logo
111 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
