Question about Brother DCP-7020 All-In-One Laser Printer
Blank vertical line on pages
Whenever I send a command to print a Word document, test page, images, and any other file types, the document is printed but appears a blank vertical line in every page of this. I tried to change the toner and the cilindrer, not all in the same time, but one-by-one, and the problem still continues...
Did someone have already problems like that??? How can I fix it???
Thanks, Fabricio
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,346 Answers
Re: Blank vertical line on pages
Open side door, should be a black assembly there with two wires, is it clean? is there any toner or hair on the wires?
Posted on Nov 14, 2007
0 characters
3 Points
Canon image runner c5800 printing vertical lines
have you ran a test page , the test will take about 30 sheets of paper it will test everything and will correct itself
good luck
Dec 04, 2013 | Printers & Copiers
Whenever i try to print a pdf file longer than one page from adobe reader, my e-studio4511 will only print the first page, followed by a second blank page, and then a final page with the following error...
Send the font information for each page in the PDF file when you print.
For Adobe Acrobat Professional 9:
1. Choose File > Print.
2. Click on Advanced.
3. Choose Postcript Options.
4. Under Font and Resource Policy, select Send for Each Page.
In Adobe Reader 9: try this 1
3. Under Font and Resource Policy, select Send for Each Page.
may or may not work try it
Hopefully this will be helpful to you all
Nov 20, 2010 | Toshiba e-STUDIO 4511 Printer
The printer prints a blank page with a line of gibberish in the upper left corner before it prints the real page.
Can you send me a "print to file" of the failing document.
At first blush it can be either of two things.
1) The preceding print job did not properly clean out the printer's memory.
2) The new print job, has data or a busted escape command in it that is being treated as printable data.
Send the print file to and I'll read through the document header to see what's going on.
Mar 02, 2010 | Dell 1720dn Laser Printer
Prints blank pages
hi jcruisedirec
Test print shows that there is no problem with he printer.
Do this:
Type just one or two words in a new document and try to print. Before printing, look at the print setup and make sure you have the correct printer name selected.
Also when you go to print, there are few options like:
  • Print All
  • Current page
  • Pages
  • Selection
If you attempt to print "selection" without actually selecting a certain portion of the document, you get blank page.
So first check that the correct name of the printer is selected.
Then test printing one page
Hope this will help you. Good luck.
If you find this helpful, please give a rating
Oct 04, 2009 | Canon MX300 Office All-In-One Printer
E-studio4511 won't print more than 1 page of a pdf file at once.
download the latest PS driver off toshibas website, due to adobe 9 update this is a known issue, newest driver should fix
May 13, 2009 | Toshiba e-STUDIO 4511 Printer
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Very slow PDF and large files printing
Change to print as an image.
Go to print then click on advance and select image.
May 21, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Same lines won't print
Sorry, but this is impossible, as a "printer problem". This is clearly a "software/buffer/document" problem.
This can ONLY happen (on two printers, same results) if the DOCUMENT has "exclusive" properties or instruction sets, or "invalid data" for the "missing" lines. For example, you may be printing an HTML document with "DO NOT CACHE" meta tag or java instructions about specific lines or form entries. Many sites (like banks, registration, or encrypted mail/login pages) do this as a security measure to prevent critical data from being inadvertently printed (and ending up outside in trash cans for an ID thief to pilfer). Other possibilities: The lines are NOT text data, they might be IMAGES of text, and saved in a format the printer/buffer does not support. Any of these examples would allow the software to DISPLAY the specific (missing) lines of text -yet NOT print them.
To test my theory (almost a certainty really), simply open the document and select PRINT SCREEN key (or use whatever key commands capture the screen as an image). This copies what YOU see, to the clipboard as a single "image" file (instead of a variety of ASCII characters, images, and code).
Next, open "PAINT" in accessories under MSlop (or any IMAGE editor like Photoshop, Gimp, etc)
Select NEW and agree to the screen size you are using (1024x768, 800x600, 1280x800, etc)
Select PASTE from file menu (or CTRL/V keys). Your document will now appear.
Print the document. The "missing lines" will now show up! If the document is too long for one screen shot, you may have to scroll down, recapture (PRINT SCREEN, etc) and paste one or more images into each other before printing it as a single IMAGE.
Nov 18, 2007 | Canon PIXMA iP90 Mobile Printer
HP 1320 PCL
check the printer driver properties settings. look under printing preferences and check the settings there.
May 07, 2007 | HP LaserJet 1320 Printer
Brother DCP-7020 All-In-One Laser Printer Logo
439 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
