Question about Sanyo Office Equipment & Supplies
Projector powers on but doesn't display anything. It stays on for less than a minute and shuts down. Sounds like it tries to start up 3 times before shutting down. I've cleaned all filters.
Marrie
  • 563 Answers
SOURCE: Panny AE 700 Shut down
Done
Posted on Apr 15, 2008
Marrie
  • 563 Answers
SOURCE: projector indicates overheating and shut down
HI there
Is there any on scren messaes before shutting down and when shutting down - which of the LED's on the unit is flashing and what colour ?
Posted on Apr 21, 2008
jyackle5
  • 8197 Answers
SOURCE: Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Posted on Mar 12, 2009
joeshea123
  • 65 Answers
SOURCE: The projector suddenly shuts off.
have you check the filter?
Posted on Mar 27, 2009
projdoc
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
Shutting down after about a minute of powering on
Sounds like a overheating issue. Clean your vents and filter (if it has a filter).
Mar 12, 2014 | InFocus IN1503 DLP Projector
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
Projector doesn't turn off when I press the off button ....I have to disconnect the power cable to shut it down
All projectors take a bit of time to shut off, when pressing the power button it first shut off the lamp, than the fan runs for some time after to cool down the lamp, have you waited long enough??? if after a minute or two, if it is still running than try pressing the power button on the unit it self, it could be a defective remote as well.
Cheers!
Jun 29, 2011 | Epson EMP-6100 Projector
System runs from about 3 to 15 secs then shuts down. That doesn't give me enough time to do anything in the BIOS setup when pressing F2. Then the system refuses to start (by pressing the power button)...
Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged. The computer should stay on even without an operating system or hard drive installed.
Jun 24, 2011 | Dell Precision Workstation T5400 Quad Core...
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Panasonic AE100U Keeps shutting off
I have exactly the same problem. I was told by Panasonic sales rep that a shipment of AE1000U projectors came in that have a faulty board (he thought optical board but wasn't sure). Only solution is to replace the faulty board.
Oct 06, 2008 | Panasonic PT-AE1000U LCD Projector
Acer PD100 overheating
I found that by resetting the factory defaults the problem goes away. I have experienced this issue a few times after attempting to correct colors.
this projector does not have the best picture or color quality.
May 07, 2008 | Acer PD100 Multimedia Projector
174 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
