Question about Shredder Office Equipment & Supplies
Why Aptiva HD pro discontinued
Shredder tilted over backward, very top heave, after using for about 4 minutes. Returned to upright position to find that the power no longer works. Unplugged the schredder, waited about 30 minutes, still did not come on. Called customer service and their recommendation did not help. Even though I had shredder less than a year, was told that they could not replace because it tilted over. Anyone had problems with shredder power failure that would not come back on at all. This is reference Model # HD Pro 1600 (Aptiva)
  • Shredder Master
  • 3,957 Answers
You may want to contact a local business machine repair service and ask if they can repair the unit. Many times they can repair what the manufacturer does not want to handle.
Posted on Apr 22, 2015
Hi i have a dyson dc 28. How do i recline it also the suckson i at the top of e handle where the red flap is. PLEASE HELP!!!
Put your foot on the indentation on the side of the head and tilt the handle backwards.
The suction from the flap on the end of the handle will stop when it reclines. That function is to allow the use of the hose with the cleaner in the upright position.
dyson dc28 manual Google Search
Oct 05, 2017 | Dyson Vacuums
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
How do I adjust the front headrest on my 2009 Lincoln MKS so that they do not tilt so far forward?
I turned my headrests backward. Worked great. In fact, I wonder if the engineers designed them that way but the production guys build them backward???
1) Tilt the seat way back to allow room to remove headrests, 2) Press and hold both headrest release tabs at the same time and have someone else pull out the headrest completely, 3) turn the headrests backward and insert into the two headrest guide slots (headrests fit the same either way). 4) No more pain in the neck !!!
Caution: I do not know what this does for whiplash injury protection but it seems OK for my own comfort with the solution. And it beats the pain in the neck caused by the bass-akwards design.
May 13, 2012 | 2009 Lincoln MKS
To transport a loewe spheros 42 plasma unit with rotating stand does the tv unit detach from the stand? I understand that the plasma tv should be transported in an upright position only is this true?
Yes, it should be transported in upright position.
When we moved, our moving company arranged a crating company to crate our Spheros unit. They built a crate around the TV and secured it in an upright position along with the rotating stand. They then put a tilt sensor (you get the serial number of the tilt sensor) to make sure that the moving people don't tilt the crate. They also un-crate it at your destination. The only problem is that the TV is already quite heavy to begin with (~180 lbs), and with the crate, it becomes almost impossible for the movers move it in perfect upright position....though our movers really tried hard.
Sep 30, 2010 | Loewe Spheros 42HD 42 in. HD-Ready Plasma...
Black part connecting the drop down foot i do not know how to put it back in please help!! thanks
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    Jun 15, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
    Dc07 model, cannot get it to stand fully vertical upright. It is as if something is not sliding back into position right. Don't want to force it in case something breaks. The upright of the cleaner has...
    Step 1.
    Step 2.
    Step 3.
    May 02, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    I cannot get my vacuum in an upright position. How can I do this?
    Try this quick repair and see if this fixes your Dyson:
    Step 1.
    Step 2.
    Step 3.
    I hope that this was helpful to you. Please feel free to use the Clarification Request form here on Fixya if you have any questions.
    Thank you,
    Chris J.
    GoVacuum.com
    Apr 12, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
    What is your opinion about the Craig 15'' high definition LCD TV? Is it discontinued? Is it a decent TV?
    I purchased Craig CLC501 from CVS and I am very satisfied. The picture and sound are great. There are many adjustments through a menu but you also can change settings with dedicated buttons on the remote. You can add and delete channels for easy channel surfing. The tuner does a good job picking up week signals with an antenna. It has a QAM tuner for HD channels on cable systems. The inputs on the rear are HDMI, YPbPr, S-VIDEO, VIDEO, RCA AUDIO R/L, PCAUDIO, VGA Port. It has a headset output jack that can be used for external speakers. The 12 volt input accepts the universal power supply for use in an auto.
    Oct 13, 2009 | Televison & Video
    Shredder won't shred - all paper is cleared - works intermitantly
    Run the shredder in "Reverse" mode for 15 seconds.
    Oil the cutting head thoroughly as this is a High Security shredder.
    Test it at 4-5 sheets.
    They always overrate the capacity but if you want to keep it operating, shred 3-5 sheets max.
    Running for serveral minutes could be due to dirty optic sensors. Unplug the shredder, remove the top (2 screw underneath front and 2 in back). Remove the sensors (they have a little pushbutton tab) and clean thoroughly with a soft cloth. Re-insert the sensors ensuring they lock in place, reset the top cover and test.
    Jun 05, 2008 | Geha Primo 3900 HS Shredder
    No Power!
    Check and make sure the paper catch bin is locked into place.
    IF the shredder doesn't see that the bin is in place, the shredder will appear dead for safetly reasons.
    There is a possibility that the control board was cracked but the only way to check that, is to take it apart and check.
    Good luck.
    Jan 06, 2008 | Tech Solution TS-4500 Shredder
    125 people viewed this question
    Top Shredder Office Equipment & Supplies Experts
    Ross Keen
    Dave Reilly
    Level 1 Expert
    Gilbert Ruiz
    Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
