Question about Whirlpool Dishwashers
I have a whirlpool dishwasher, Model DU1345XTVB1 and the unit will fill up with water but won't wash or drain. Any idea what may be the problem?
I did change the door switch and checked the float and motor and both seemed to be Ok
  • 641 Answers
SOURCE: Not enough water
Be aware that you should remove dishwasher's power cable before touching wires or making resistance measuring !!! Check that the inlet valve get power. In case it does and no water entering the tub, check with multi-meter for solenoid's resistance (disconnect first the wires to it),if no measurement result, you should replace the valve. In case you have a measurement result, remove the solenoid from the valve and check that it's clean from any dirt. In case there is no power to the inlet valve - check that the float switch works. This is usually a small switch attached to a float. The float (usually a cylindrical) located inside the dishwasher at the bottom. As the water level rises, the float rises too. When it reaches the certain height, the float activates its switch, which cuts the electricity to the water inlet valve. If the switch is defective (stuck in the disconnected position)it will prevent power from the inlet valve. The switch is an On/Off switch and you can check it easily by a multi-metr. Good luck !!
Posted on Jun 08, 2006
  • 4 Answers
SOURCE: Dishwasher drains continuously
I dismantled and checked various parts of the dishwasher and everything seemed to be working. I noticed with a phase tester that the pressostat never got any voltage. This led me to check the microswitch on the door which turned out to be broken (never making any connection). This is the microswitch that turns off the dishwasher when someone opens the door.
So an unusual problem - two faults at the same time i.e. clogged and overflowing drain and broken door switch!
I ordered and fitted a new door switch and now the machine is working fine again.
Posted on May 30, 2008
SOURCE: Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Posted on Dec 13, 2008
SOURCE: Stays in wash cycle Whirlpool Dishwasher Du1050SS
my repairman contacted whirlpool about my washing machine staying on
wash.. to his surprise.. and mine.. and his co=workers.. this is the answer,
it worked.. and we have never heard this before.
In your original istallation booklet it tells you to let the dishwasher run til its complete
the first time you use it as it may rinse twice... my original installation man told me this also.
however.. if you suffer a "blip" in your electricity.. it could put the little dishwasher "brain"
out of whack.. it can run as long as 3 to 4 hours on wash to reset itself.. if you stop it
(like others have mentioned.. and which I did also).. it doesn't complete the reset and it
will attempt to do it the next time..
answer?.. just let it go once as unnerving as this is.. it works.. They did mention that
if it went to 5 hours.. call your repairman because you need a new mechanism.
karen in Dothan
Posted on Apr 03, 2009
  • 10865 Answers
SOURCE: Dishwasher always fills to float valve
There are actually several possible causes of your problem. I will briefly describe each in hopes that you can isolate the problem and will then know how to proceed.
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Aug 02, 2009
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
My whirlpool gold dishwasher is only 2 years old. It will fill with water but it just sits and makes a clicking noise when its supposed to be washing. It drains fine when I push the cancel button.
sounds like there is either a loose wire or bad switch on the water flow pump, not the drain pump What is the model number of the unit that your working on?
Aug 22, 2015 | Whirlpool Dishwashers
Whirlpool DU1345XTVB1 shuts off during water fill but if you keep restarting it will eventually work. Control Board or something else?
Sounds like the water valve sticking in the back, check your screens for trash or minerals , if not then go back to your control switch
Jan 08, 2015 | Whirlpool Dishwashers
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Yes I have a whirlpool DU1345XTVB1 dishwasher. Just got in July. After each wash cycle the dishes are not dry. I have been using Finish gelpacs w/jetdry & also have a off brand drying agent in...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Check your heating element.. </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">A bad heating element causes many problems in dishwashers&hellip;<br /><br />Dishwasher Problems The Heating Element not Working<br /><a href="http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not" target="_blank">http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not</a><br /><br />Dishwasher Maintenance<br /><a href="http://www.fixya.com/support/r4319937-dishwasher_maintenance" target="_blank">http://www.fixya.com/support/r4319937-dishwasher_maintenance</a><br /><br />heatman101 <br /><br />Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes <br /><br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 27, 2010 | Whirlpool 24 in. DU1050SS Built-in...
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool built in dishwasher. not aware of model number
Putting vinegar in the bottom of the dishwasher is not going to help because it has nothing to do with the FILL cycle. The bottom (or sump) actually is used during the WASH and DRAIN cycles. I would check the fill port where the water inlet hose goes into the side of the wash tub. You will need to pull the unit out and locate the inlet hose on the SIDE of the dishwasher. The hose should be a black rubber hose located on the left-hand side of the machine. I had a very similar problem that turned out to be calcium deposits clogging the fill port BEFORE it got to the fill valve. With the unit turned off, I removed the rubber hose and used a small screwdriver to poke straight down into the fill port and break up a bunch of calcium. The unit worked fine after that. It is normal for some dishwasher models to drain if they do not detect enough fill water, or if they detect a leak. Usually when the fill port becomes restricted or clogged you will find puddles of water forming under the dishwasher. You might want to remove the bottom panel and check for leaks as well (if you haven't done so already). If you check the fill port and it is clear, the fill valve could be a possibility as well. However, you mentioned you could hear water running which leads me to believe that you have a simple clog somewhere...but, the valve could have accumulated some deposits as well. Check the fill hose and let me know. Good luck and I hope this helps you. PS Another common mistake people make is to put drain cleaner in their dishwashers. This can damage the pump and chopper assembly. Not to mention, it could be harsh on the some of the rubber seals. Not a good idea.
Jul 30, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
59 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
