Question about Dryers
My dryer keeps stopping while cycle and error massage displaying AF2 what i can do plz suggest me
  • Dryers Master
  • 5,323 Answers
POSSIBLE DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
My dryer keeps stopping while cycle and error mass - dryer-keeps-stopping-while-cycle-error-2twpke0famvgldalck04zdql-3-0.jpg
Posted on May 05, 2015
Frigidaire affinity dryer code ad
Hey Cindy, thanks for your submission!
I see that your Frigidaire dryer is displaying an error code of "ad". The "ad" error code will display with the "Auto Dry" cycle has been selected. If you did not select the auto dry cycle I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord for at least ten minutes. Once power has been restored to the dryer and if the error code is still persistent you may need to have a replacement control panel or wiring harness installed. I would recommend having electrical parts replaced by a professional technician this will prevent any personal injury. Best of luck! -Matt
Mar 08, 2016 | Frigidaire Dryers
Ad error code
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# AGQ7000E. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire AGQ7000E Gas Dryer
Dryer keeps stopping cycle
The most common cause of the error is lack of airflow. Check the exhaust output and see if it is restricted, you may have to check the venting in the building and unhook the dryer from it to check and see. If it runs unhooked from the exhaust system then it is a venting issue. IT could also be plugged lint screen, loose fan motor or obstructed fan. If it is not any of those then it is the thermal sensor or thermostat that is bad.
Jul 09, 2013 | Miele Dryers
Maytag dryer MD-24 error symbol?
The dryer completes the cycle you have set. If you do not remove the contents at the end of the cycle, the dryer performs the start-stop routine you describe until you get around to removing the contents. Eventually even the start-stop routine ends and the contents just lie in a heap until removed
Mar 11, 2013 | Dryers
Tumble dryer displaying E90 error
do you have the machine's manual ? if you do try and find out what the message mean
Mar 23, 2012 | Zanussi ZDC5350W Electric Dryer
My canon MF4320d printer is showing SYSTEM ERROR E225. Kindly suggest a solution.
change the scanner because this massage show when our scanner stop moving or break or jam candition in many case scanner cable create problem those are connected the printer logic card
Sep 21, 2010 | Canon Office Equipment & Supplies
Samsung dryer DV328AER doesn't turn off
My Samsung dryer 8KG (SDC3K801) is not turning off after completed the cycle time. The panel showing end but the drum still running. If I choose Synthetics extra dry with auto cycle time 49, when the timer at 6, the display increased again to 25. It's seem the dryer is not stopping forever. Any suggestion please!. Thanks
Jul 20, 2009 | Samsung DV328AE Electric Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Hotpoint wd865 dryer stopped working
I always start at the plug to make sure it has 220, a dryer will run but no heat with 110. This was a common problem when everyone used fuses instead of breakers, just an old habit.
Then I check the heating element and thermostats, this must be done with an OHM meter. More than likely it will one of these.
Dec 23, 2008 | Hotpoint Ultima WF865 Front Load Washer
Dryers Logo
62 people viewed this question
Top Dryers Experts
