Question about Mach Speed Trio Stealth G2 8 inch Tablet with 8GB Memory
I have it plugged into computer with usb it is still not charging & will go to date screen & that's it!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 120 Answers
These tablets appear to have problems. Take a look at these posts and see if you can glean some help. 8 8GB Trio Stealth G2 Android
Posted on Apr 24, 2015
I can't figure out how to charge the battery. I rec'd a AC wall charger but I can't figure out where to plug the male end in on the tablet
The charger plug should plug into the mini-USB port. This is the same port for the USB cable that would connect to the computer, and in fact the tablet can be charged from the computer if the computer is on.
Mar 23, 2015 | Tagital Tm 9" Android 4.0 Tablet PC...
My prestige elite 7 tablet will not charge even when plugged into pc through usb chord.
Try using a USB charging cable that plugs into a wall socket (via adapter), rather than using a cable plugged into the computer. Computer USB sockets sometimes have lower power ratings and are insufficient to charge tablets.
(It is not clear if you have successfully charged on computer before or not). Also just try a new cable if you have not as they can become damaged (get one with a decent make - sometimes the very cheap cables and charges are poor quality and do not work well)
If none of that helps / you have tried it all please reply and I will try to help further.
Dec 07, 2014 | Tablets & eReaders
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
My i pad will not turn on
First steps: Make sure you're up to date
  1. Verify you have installed the latest version of iTunes.
  2. Verify that you are connecting iPad to your computer using a USB 2.0 port.
  3. Make sure your iPad software is up to date: With your iPad connected to your computer, click "Check for Update" in the Summary section of iTunes.
  4. Charge your battery: Using the USB power adapter that came with iPad, charge iPad for at least 20 minutes before further troubleshooting. If necessary, refer to "Charging the Battery"
Jul 07, 2014 | Apple iPad Tablets & eReaders
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
How do I charge the iPad battery.
USB hubs typically don't generate the 10 watts necessary to charge an iPad when it's connected to your computer. This basically means you can't use your laptop to recharge your iPad.
Apple recommends finding an AC outlet and using 10-watt power adapter that came with your iPad.
Jan 08, 2012 | Apple iPad2 WiFi 64GB
How do i charge my kindle comes on screen battery flat
You kindle should have come with a usb cable (one end is different from the normal usb on things like pen drives) and also a little plug with a usb port on it. If you plug these two together, then plug the other end of the cable into the kindle, once you plug the actual plug into the wall, your kindle should start to charge (you can see this by a light appearing on the bottom of the device). You can also plug this cable straight from your kindle to the computer. This will also charge it (though slower than through the mains).
Sep 11, 2011 | Amazon Kindle 1
Mach Speed Trio Stealth G2 8 inch Tablet with 8GB Memory Logo
128 people viewed this question
Top Mach Speed Tablets & eReaders Experts
BrikimG
Level 1 Expert
David Payne
David Payne
Robert Graf
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
