Question about Intex Pool & Spa
My spa pump keeps triggering my circuit breaker off every time i try to use my spa now
    Sergeant:
  • 258 Answers
Faulty pump try another
Posted on Apr 22, 2015
Why the circuit breaker keep trowing off ?
Could be a short in the cord somewhere. This will keep tripping the breaker. If you can check the socket and plug for loose wires or check for damage along the cord.
Jul 25, 2014 | Rule 1800 H53SP-24 Swimming Pool Cover...
Reset Jandy PS6, still flashing red and green
turn off heater if ok then replace ignitor if not keep removing auxs until stops blowing breaker
Apr 02, 2014 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
My spa depot hot tub keeps popping the breaker
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
http://waterheatertimer.org/How-to-wire-GFCI.html
What type breaker?
GFCI or ordinary heat-rated breaker?
Do NOT use two GFCIs on same circuit.
Spa needs GFCI to protect people while immersed in water.
You might have dangerous short, or leaking element, bad switch, bad wiring, bad electrical connection, or undersized wire and breaker.
If breaker is undersized for load, it can get loose on the busbar and then start arcing, and then tripping. Use nose to smell for burning. Feel breakers to see if they are warm. Move wire to different same-size breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 18, 2013 | Pool & Spa
Air lock for my aruba spa hot tub how do i fix it
This sounds like a problem with the circuit board inside the spa control box.Do this:
  • Turn the breaker off
  • Unplug everything that is plugged into the circuit board i.e. the pump, heater coil, air blower, light etc.
  • Turn the breaker back on
If the circuit board stays on then you have to go thru the process of plugging one item at a time turning the breaker on then off to find the part that is bad.
Rod
US Parts Center
888-521-6183
Dec 19, 2012 | Pool & Spa
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
Hello i have a spa and i just installed a 60 amp gfci breaker and it keeps popping the breaker. idea
generally applliances, like refidgerators heaters, anything with motors don't like gfci's... or gfcis don't like them. take out the gfci breaker and you should be swirling in no time,... when's the party?
Dec 11, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Pump trips circuit braker as soon as it is turned on
The problem is either in the spa or the circuit breaker itself is faulty. I would begin by changing the circuit breaker as it is much cheaper than a new pump.
Jul 06, 2009 | Pool & Spa
Why does the breaker switch off as soon as i turn on the heat
Two possible reasons- the circuit that the pump is connected to (the plug it is on) has too much power draw from other appliances running on that same circuit. Or, there is a short in the pump, causing it to draw excessive power and trigger the breaker.
Is this a recent development? Is the pump on a shared circuit or does it have its own breaker?
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
69 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
