Question about Karcher Garden
K2.35 water leaks thru trigger handle - Karcher Garden
    Sergeant:
  • 258 Answers
Seal with silicone sealant
Posted on Apr 22, 2015
How to stop water getting inside a single leaver shower faucet?
quite possibly there is a broken O ring inside the faucet .
Jul 17, 2015 | Home
Have a Karcher kb4040 that continues to run constantly even when the trigger isnt pressed. Also water flows out of the detergant hose when im not pressing the trigger. Pressure seems down slighlty, not...
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Oct 13, 2012 | Garden
Installed a new 88976 handle but still have a leak
replacing just the handle cannot fix the leak and common sense should tell you that.... try turning off the water to the diverter (thru access panel on opposit wall or main water valve for the home) and then replacing the stem or cartridge inside the diverter -- this is what controls water temp, pressure, and is responsible for any leaks you may have...
Aug 31, 2009 | Delta & Single Handle Shower Faucet
Karcher 1650 leaking water from trigger
i believe the spring is the actual trigger spring that pushes the trigger switch back in place and the water leaking out is probably a seal issue
Aug 25, 2009 | Karcher Garden
Water is leaking out my waste line when using recirculate.
Replace the internal "wagon-wheel" looking gasket inside the valve. Its job is to keep the water going thru the valve and ports the handle is set to and not leak out of the waste port.
Aug 08, 2009 | Hayward SAND FILTER, PRO SERIES
No hot water
if the leak is behind the handle take the handle off and tightn the packing nut, do not over tighten, as far as luke warm water is this with just one facucet on, they way these tankless water heaters work they are by gpm, gallons per min, if you have more gallons of water going thru the unit then it is designed for then it won't get hot, if your water pressure is to high going thru it will push it to fast thru the unit and won't get hot, your house pressure should be no higher then 75lbs no lower then 65lbs
Feb 25, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
BOSTITCH AIR POWERED NAILER - AIR LEAK THRU TRIGGER
sounds like the rubber seals have dry rotted prob from not oiling it enough, but you should be able to go on the Bostitch web site and order new rubber seals for the gun
Sep 29, 2008 | Air Tools & Compressors
Water leaks where the hose connects to the trigger handle.
Be sure to get a good washer on with the connection. They're easy to buy at any hardware store. You can also put white plumbing tape around the threads before screwing them in to make it really fit.
Sep 28, 2008 | Bissell 1631 PowerSteamer ProHeat Canister...
Garden Logo
142 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
