Question about Air Tools & Compressors
I HAVE 7.5 HP VERT 80 GAL TANK COMPRSSOR IT KEEPS BURNING CONTACTS ON PRESSURE SWITCH. CONTACTS STICK TOGETHER AND COMPRESSOR WON'T SHUT OFF AFTER REACHING PRESSURE. WHAT'S CAUSING THIS?
    Master:
  • 439 Answers
Contacts on switches, contactors, starters are rated in amperes, volts, and horsepower. Your motor is probably a 40 amp/230V/ 1phase on a 50 amp circuit. If it's a 3phase motor, it is a 25 amp motor on a 40 amp circuit.
A 7.5 HP motor should be on a contactor or starter, not on a pressure switch because of the amount of current or amperes used. Otherwise, use a pressure switch rated for 7.5 horses at voltage supplied.
Posted on Apr 23, 2015
  • 125 Answers
There is a capacitor across the contacts
To absorb the inductive collapse if the motor.
But this problem usually only happens to DC motors not AC.
If the starting Cap has 2 leads I'm stumped if it has 3 leads replace it.
Posted on Apr 22, 2015
Pressure won't re-build after cut-in
So you are saying that it starts and builds pressure and then shuts off, then when it comes back on again, there is no pressure? Sounds like the unloader valve is sticking open.
Aug 08, 2013 | Craftsman 3 gal. Air Compressor, 1 hp,...
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
Jan 17, 2013 | Porter Cable C2002-WKR 150 PSI, 6 Gal....
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
Air compressor want build over 40LBS air!
It sounds to me like you have a bad pressure switch. When these go bad, it takes less pressure to close or open the contacts to shut the motor down. You can get a replacement from any Ace Hardware. It will come with basic install instructions. Just follow those and you should be fine.
Aug 03, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Compressor keeps blowing release valve
Compressor pressure switch not working properly. Remove cover over pressure switch. Drain air out of tank. pressure switch contacts should open. If contacts do not open they may be stuck or welded close. Remove power and gently pry contacts apart. If they where welded together this will correct. If this doesn't correct replace pressure switch
Jan 16, 2011 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Tank pressure 120 regulated pressure 200. how can
If your pressure cut-off switch is faulty, it will keep running. Could be very dangerous. MSC has switches with different ranges. I had this problem once with an 80 gal. compressor. It was running and I cautiously walked over and shut it off. At this point it had 200psi built up. Yes, I was scared but a new regulator fixed it. The old contacts were rusty and wouldn't release. Hope this helps.
Terry
Nov 18, 2009 | Dewalt D55146 Factory Reconditioned 4.5...
Ir 7.5 vert 80 gal comp,..works and works good,...but upon startup,,motor sparks,....whats up with this?????
Same as all my 220v compressor motors. Contacts make and then enable (maximum) start-up current inside motor (brushes). Only flashes for a moment....startling yet normal. Hope this helps!
Jul 12, 2009 | Ingersoll Rand Type 30 Reciprocating Air...
Craftsman compresser md 919155730
This sounds like a pressure switch failure. follow the power cord to where it enters the compressor and the switch should be there. you should be able to order a new one through sears service center. Good luck.
Jun 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
99 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
