Question about Toshiba Televison & Video
My toshiba sd-k710 disc tray wont open or close
    Sergeant:
  • 258 Answers
Use a pin in the eject hole to eject stuck cddvd
Posted on Apr 22, 2015
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
I have a toshiba dvd player model sd-k600, i need change of zone 1 to mutiregion o zone 4, can you tellme how te change, tahnks
Press Open button on your remote control to open the drive tray
and remove any disc
Press 2403960
Press Enter button on your remote control
Press 9 for multi-region playback
Press Open button on your remote control to close the drive tray
Power OFF the DVD player
Power ON the DVD player
Jul 16, 2011 | Toshiba SD-K600 DVD Player
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
How do i make my tosiba sd330 region free
  5. Power off
Nov 06, 2010 | Toshiba SD-330E DVD Player
Toshiba sd 4800 dvd plater not opening and playing
There is a small belt that has become worn or has broken. Open the DVD palyer, press the open key push on the silver disc, the tray will open, . On the tray pul the two tabs up gently, remove tray. Belt is located there
Oct 04, 2009 | Toshiba SD-4800 DVD Player
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
Won't open...
Hey this is a great site!
I was having a similar problem with my Toshiba SD-K860. Bobbyj, thanks for the link to the SD-4900 service manual, it was extremely helpful even though it was a different model. I could not find an emergency eject pinhole, and leaving the unit unplugged for a while did not help (two suggestions found on other sites), so I simply took the whole thing apart, got the disc out, found the eject slider on the bottom of the tray, massaged the tray open and closed, and put everything back together again. The connections were solid and the belt was in tact so everything seemed to be fine. Once I reassembled and powered it back up it worked again!
I posted a more detailed solution on my problems to solve site, which is similar to this one:
http://problemstosolve.com/solved/toshiba-sd-k850-wont-eject-solved/
Mar 23, 2008 | Toshiba SD-4000
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Televison & Video Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
