Question about Philips Norelco 8240XL Electric Shaver
I ordered new replacement shaver heads and cutters, but accidentally dropped them while I was replacing them.
I understand you are not supposed to mismatch the heads and cutters. But since I have done that, how bad will it hurt my razor to go ahead and install them even though they are mismatched?
  • Philips Master
  • 1,602 Answers
Unless one was damaged when you dropped it, you will never know the difference.
ShaverOutlet com The Ultimate Shaver Source
Posted on Apr 24, 2015
  • Anonymous Apr 25, 2015
    Thank you. That was what I was really hoping to hear from someone who knew!
Have a microscreen rechargable tha needs blades replaced and screen replaced...can U do that and How much$$$
This is not a service provider.
Amazon.com: Remington SP-72 Replacement Head ...
www.amazon.com > ... > Replacement Heads
Amazon.com, Inc. Rating: 4.5 - ‎12 reviews
Replacement Head & Cutter for all MicroScreen 3 shavers, TA-3050, 4570, 5570 ...rechargeable and saves on batteries, so I'm using the new blade with the old ... Sincethe screen needs replacement much more frequently than the cutter, it is ...
Oct 31, 2015 | Remington Health & Beauty
I have a Braun 7570 and it is marvelous! I replace foil and cutter every year. This time after replacing it the shaver did not cut my hair. Battery still gets full charge. What is the problem?
Most likely, the 'drive unit' is bad. The drive unit is a component that consists of the swivel frame that the head snaps onto and the motor. Excessive noise while the shaver is running is also a major sign that this part is bad.
Unfortunately, Braun no longer provides these type of replacement parts for any of their shavers. You may end up needing to replace the unit.
Since you apparently like that model and you have spare shaver heads for it, you might want to consider a compatible model as a replacement. shaveroutlet.com has a new model that uses the same foils and cutters as your 7570. You can see it at the link below
http://shaveroutlet.com/shavers/foil-shavers/braun-series-1-195s-mens-cordless-shaver.html
Feb 19, 2014 | Braun Syncro 7570 Electric Shaver
Bought HQ9 SPEED-XL 5/12/07 and recenty dropped it and the top fell apart. Where can I have it repaired and new cutters installed. I live in Caernarfon, North Wales.
You will find a helpful video for assembling the shaver head at shaveroutlet.com. See link below and scroll down for video
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
Replacement blades can also be purchased from this link if desired. They ship to UK
Jan 13, 2011 | Philips HQ6990 Electric Shaver
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jan 11, 2011 | Braun Health & Beauty
I can't find replacement cutter heads for my 725 RL shaver.
Norelco 725 RL electric shaver replacement cutter heads is Norelco HQ56 shaving heads.
Sep 18, 2010 | Norelco Health & Beauty
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
Shaver started making a much louder buzzing sound, no longer shaves as well and now hurts a bit to use. Can this be fixed?
Hello Robert, It sounds like the foil screen might have been damaged and is causing poor shaving performance. Typically, a screen will get small holes or tears in it after providing good service for some years, however, these very thin screen foils, can get damaged other ways too.
The best way to restore the best shaving performance is to replace both the foil screen AND the cutter head block (cutter head) as it could be possible that the cutter blades have become damaged or nicked and have caused the foil screen to become damaged, as a result.
I would contact www.electricshaver.com and see if you can purchase a new set of the cutter block head and the screen foil for your particular Braun shaver model. As the Braun 360 is a tradename used on a couple of different model numbers, you really need the four (4) digit model number in order to locate the correct replacement parts.
Here's a link to their page with the various Braun replacement cutter blocks and foil screens. You might find your model number amoung them, otherwise, you can also give them a call at 1-888-476-1785 and ask them to assist you with selecting the proper replacement parts.
http://www.electricshaverstore.com/get_list_125.htm
As you are no doubt aware, replacing the cutter head and foil screen is the best and simplest way to restore an electric shaver to a like new shaving condition and much less expensive than replacing the entire shaver.
Nov 11, 2009 | Braun 360° Complete Electric Shaver
Need a new foil for model 5479
HI. you can order your replacement foil from this site below. your actual foil will be located in the Single foil shaver section(non-pivoting head). just scroll down a bit and the item number is(424 foil&cutter). your model number is in this section.
CLICK HERE TO ORDER
Aug 21, 2009 | Braun Health & Beauty
Need thingy that replacement heads & cutter fits into
Remington R 950 replacement heads is Remington SP 19 titanium MicroFlex replacement heads and cutters.
Jan 11, 2009 | Remington Titanium Microflex R-950...
Philips Norelco 8240XL Electric Shaver Logo
174 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
