Question about Garden
The engine starts and then cuts out immediately
    Top Expert:
  • 10,875 Answers
Clean and rebuild your carb,or go the easy and cheap way,buy a new one for about 10 bucks on ebay,gas with ethanol ruins anything with rubber,old gas seperates,ethanol is water,always drain all gas and run until dry and use only non ethanol gas for small engines
Posted on Apr 22, 2015
Friends car, he has not got a computer. It usually runs as sweet as a nut. Engine starts then cuts out. Sometimes runs for 20 minutes, then cuts out.
car starts then cuts out after 2 seconds, please help!!? ' Yahoo ...
https://answers.yahoo.com/question/index?qid...
Mar 22, 2010 - Car starts then cuts out after 2 seconds, please help! ... I went to start it this morning, it started up fine but only for literally 2 seconds then it just cuts out. .... In every after how many kms we should engine oil in the motor bike?
Engine fires up, but cuts out. - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=1128508
PistonHeadsMar 23, 2012 - When the engine is cold it needs a bit more fuel to stop it cutting out(sort of like ... If you can't do it yourself then you shouldn't need to take the car to your ... Also, starting with your foot on the throttle seems to cause all sorts of ...
What is the problem if the car starts and then dies almost ...
askville.amazon.com > Transportation > Automotive
Nov 22, 2010 - Askville Question: What is the problem if the car starts and then dies almost immediately? ... I waited for my kids, and when I tried to start it back up, theengine turned over but then died immediately. ... 1. out of gas, or bad gas
fuel system - Engine starts but almost immediately cuts out 3 ...
mechanics.stackexchange.com/.../engine-starts-but-almost-immediately-c...
Jun 26, 2014 - When I start the car the engine catches but then dies almost immediately. I have to restart the car 3 or 4 times like this until the engine starts ...
Car starts, then cuts out straight away!! - boards.ie
Jan 08, 2016 | Cars & Trucks
Why does my MTD Lawn Mower start and immediately cut off. On initial start, it ran for one minuet only.
sounds like my friend is you have a dirty which means you will have to rebuild it or you have water in your gas tank dump gas by new gas dont use the same gas
Aug 29, 2014 | Garden
Why does my lawn mower start and immediately cut off? Installed new plug and filter.
How long has petrol been in mower for. Could have fuel that has gone bad in it. Also when you start mower you usually need to start with the choke activated until the engine gets warm and then take off the choke. Also check the throttle linkage as some mowers have a device that kills the engine when the throttle is pulled down to stop and it is usually on the mower engine and gets activated when you pull the throttle cable to the stop setting. Had one where this was bent. Another thing I have had is a pin that is in the drive shaft that had broken thus causing the mower shaft not to turn with the engine.
1JZ FSE toyota Mark II - the engine can't start; it abruptly cut off. It is able to start when fuel is manually injected into the carburator but cuts off immediately this fuel dries up
sounds like your fuel pump is bad and not supplying fuel can you hear it run when you switch key to on but not turning engine over
Apr 14, 2013 | Toyota Cars & Trucks
My mazda soho 1.4i cuts out when you stop at the stop street or robot and she doesn't rev up?
Check out the related help links with solutions to troubleshoot the problem.
Click the link below:----
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
Volvo 760 engine cuts off frequently while driving? http://schematicsdiagram.blogspot.in/2012/02/volvo-760-engine-cuts-off-frequently.html
Car starts and cuts off immediately? http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
While stop engine idles like cylinder missing? http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
These details will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
My nissan maxima 300SE cuts out while driving
Its can be spark plug issue or low fuel pressure issue or clogged fuel fuel filter issue or can be due to problem in ECM.There are many possibilities that can cause such problem. For proper step by step troubleshooting.Click the link below and go through troubleshooting.
--------------Engine cuts off when reaches 2000 RPM?
-------------Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
--------This will help.Thanks.
Jun 05, 2012 | Nissan Maxima Cars & Trucks
Will not run under load, seems to be starving for fuel. When I leave it for a minute or two, I can start it and work with it for a minute or so then it sees to over rev before cutting out. If I start it...
Check the fuel filter in the tank for plugging. Check the fuel lines for kinks, rotting, or splits. Check the muffler and air cleaner for plugging. Make sure all the screws and mounting nuts are tight on the carburetor. When these things look ok, then turn the H needle jet CCW about 1/2 turn, start the engine and let it warm up. Open the throttle fully--the engine should be 4-stroking now. Proper adjustment is when the engine will 4-stroke, but immediately 2-stroke when cutting. You may need to turn the H needle somewhat CW to achieve that condition. Hope this helps!
Apr 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi..1990 ford laser..engine turns over but wont start..plenty of petrol..battery good..starts after leaving for a few hours..runs for short time then cuts out again..think it may be ignition module--any...
maybe alternator is stuffed, try gettin it runnin and immediately disconnect battery while ya engine is runnin then if ya engine cuts out that may be your problem.
Apr 08, 2010 | Ford Laser Cars & Trucks
1993 lesabre cuts off
Behind the crank shaft balancer there is a crank shaft position sensor. This should take care of your problem by replacing it.
Dec 29, 2008 | 1998 Buick LeSabre
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
