Question about Panasonic WORKiO Office Equipment & Supplies
How can I fix a paper jam in my Panasonic 4530 ?
Yes it was helpful. Thank you very much for your responses. I guess my message wasn't clear yesterday; the ADF works fine and is not the source of the paper jam. The internal paper path J50 message displays when using the ADF to copy, or printing to the machine. Yet copying on the glass works fine even when making multiple copies. Yesterday, I looked thru the machine and paper path thoroughly, and didn't find any small pieces of paper. Is there a different internal paper path when copying from the glass? If not, then shouldn't the paper path jam occur there as well? Your advice for a fix is be greatly appreciated.
  • 1,602 Answers
Look inside the printer, some where in or around where the paper feeds from the area there is a piece of paper that is stuck or has ripped off inside the machine, you going have to look with flashlight follow the feed rollers and you will find paper, paper clip, a staple, dirt, something blocking the rollers or feeder from working right.
www.ask.com/panasonic_4530_paper_jam/
www.ask.com/panasonic_4530_error_code_j50/
www.ask.com/panasonic_4530_where_is_paper_jam_located/
Posted on Apr 22, 2015
  • 6 Answers
Does it try to pull in the paper at all? If it can't drag the paper open the top door and see if the 3 rollers are worn down (bald) or dirty. Clean the rollers with a soft cloth dampened with a bit of window cleaner solution.
If it pulls the paper in but it is getting stuck look for any obstructions in the paper-path (as Rod Gandy said it above).
If the paper is getting stopped where it turns down towards the scanner see there is a small black actuator for the paper path sensor. Usually if users drag out the stuck paper that can pop out , or hold back a small piece of paper.
(To remove/fix it:
Lift up the ADF ad you'll see 2 big screws of the bottom front holding the front panel. Remove them, and take off the front cover of the DF. To do this you have to lift the DF feed tray a bit. Then close down the DF and find 3 small screws on the front left - they are holding a square plate with gears behind it. Remove them and the plate. Than there is a small triangle-shaped plate behind it with one small screw. Take that screw off and remove the plate - it has the door pin on the other side of it. Take off the ADF door. You will see the mentioned actuator in the middle, behind a long steel plate. That plate has 2 screws on the front, nearby where the mentioned triangle plate was. If you take that 2 screws off, you´ll be able to remove the long plate. Check the actuator has it's spring and is sitting correctly - if not, fix it.
Re-assemble it following the same steps backwards.)
Posted on Apr 23, 2015
Paper jam in tray
when u switch on the printer , does it motors works and u hear it like before?
if yes then it's paper sensor is corrupted and should be fixed or changed by repairman
if no then there is paper in and you should try to exit paper...
Jun 26, 2013 | Samsung ML1865W Laser Printer
After clearing a paper jam incorrectly
Please check all places and follow all the steps here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00441807&cc=us&lc=en&dlc=en&product=441125
Thank you
TechSaver
Feb 05, 2010 | HP Officejet 5610 All-In-One InkJet...
Error Message C5100 Kyocera KM-4530
your main charger is shot... order a new one...
Dec 18, 2009 | Office Equipment & Supplies
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
Printing envelopes from bypass tray
Yes insert and selct the thick stock
Dec 01, 2008 | Panasonic Workio DP-4530 Copier
Panasonic DP 4530
E4- 02 Paper Jam 1. Paper Jam in Fuser Unit.
2. Paper Exit Sensor 1 or 2 is disconnected.
3. Paper Exit Sensor 1 or 2 is defective.
4. DRV PCB connector is disconnected.
5. DRV PCB is defective.
6. SPC PCB connector is disconnected.
7. SPC PCB is defective.
Oct 19, 2008 | Panasonic Workio DP-4530 Copier
Paper jams at finisher when making multiple copies. Using 20 lb. paper. Any suggestions? Copier is Panasonic Workio DP-4510 with detached finisher.
first try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Sep 27, 2008 | Panasonic Workio DP-4530 Copier
Panasonic UF-490 Fax "Power Failure 887"
try the all job clear.. press the ff.
FUNCTION 7 Monitor(4 times) then *(asteris or star)
Service mode is appear.. scroll arrow down.. select Ram initialize by pressing set.. then scroll down look for All Job Clear then set..
Aug 31, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
Panasonic fascimile paper jam
pleaz check the paper path sensor any of them is not working or small piece of paper can be there
Aug 17, 2007 | Panasonic Workio DP-4530 Copier
352 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
