Question about Karcher Garden
Karcher pressure lance how to get out the plastic rivots
How to remove the plastic rivots from the lance
    Master:
  • 585 Answers
WHY WOULD YOU WANT TO REMOVE THESE, THE REST IS GLUED TOGETHER I BELIVE
Posted on Jun 27, 2016
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
aroostookb
  • 98 Answers
SOURCE: Karcher detergent draw problem
return it to Walmart
Posted on Jun 23, 2009
  • 32 Answers
SOURCE: Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Posted on Jul 04, 2009
  • 9 Answers
SOURCE: I have a karcher kb9030 pressure washer it runs
I assume you have run some water through the supply hose before connecting it up, they don't like pumping air. The most likely problem is a blockage at the inline filter where the supply hose enters the unit. If there is no filter there then the problem may be more serious. Grit may have entered the pump and worn out the pistons and then you may as well buy a new one because it won't be worth repairing.
Posted on Jun 02, 2012
  • 28 Answers
SOURCE: karcher 2.56 keeps pulsing on and off whenever high pressure nozzle is attached. I have tried different nozzles and same thing is happening. when i press the lance without any attachment it works fine
Make sure you have bled all air from the system. Also make sure you have sufficient water supply; if house water pressure is too low or if your hose is too long or doesn't allow full flow, you may not be getting enough water to the unit.
Posted on Apr 16, 2015
Karcher troubleshooting
check your lance nozzle is not blocked... Remove the lance from the trigger assy and see if you have water coming through then. If you do then the nozzle is blocked :@)
Jul 21, 2014 | Karcher K2.26 Electric Power Washer
Karcher lance fitting
if they are the plastic version, replace them as they tend to "expand" as they age and won't fit properly.
Jul 08, 2014 | Garden
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
Pump working - no pressure from hose. B2002?
Sounds to me that you may have a blocked high pressure jet.
Dec 13, 2009 | Karcher K2.26 Electric Power Washer
Dear sir/madam I bought a kArcher model K3.97
Peter , sorry to say but there is no replacement parts for that lance , you just replace the entire thing
its called a Dirtblaster lance
Nov 08, 2009 | Karcher K2.26 Electric Power Washer
Jun 29, 2009 | Garden
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Karcher K2.89
Dear Pajodi,
I just came across your problem. I have just joined FIXYA, and solved various Karcher problems. First of all with all respect, the shop from where you bought the machine, must have told you all necessary instructions to operate your machine.
Now the soap always works on low pressure. So if you have a variable lance, turn it to low pressure. You can also remove the lance, and the soap will surely starts to work. With turbo lances, the soap system does not work. This concludes that the soap does not work when high pressure is used. Bigger machines do spray soap at high and low pressures. But these have regulating knobs, to swith off and on, the soap supply.
Regards,
MG.
Jul 21, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
145 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
