Question about Locks & Locksmithing
Brinks electronic safe keeps beeping 5 times, changed batteries and reset combination but it keeps beeping
I'm able to open the safe with the combination and can reset the combination and I have changed the batteries a few times. The safe seems to work, but it keeps beeping 5 consecutive beeps every few minutes Any help?
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Posted on Sep 16, 2008
SOURCE: My Motorola H700 battery is drained in 5 minutes after a full charge
how to replace battery of motorola h700 bluetooth hedset
Posted on Nov 12, 2008
SOURCE: need to reset combination on brinks digital home safe model 5040
the Brinks Company has a phone number you can call to get instructions on sending them a letter for a combination. It is 1-800-832-5834
Posted on Feb 12, 2009
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
I changed the batteries on my safe and it doesn't recognize the combination any more.The door is open but the dore is now in the locked position.
As long as the door is open you should find a reset button somewhere. Put in fresh duracell batteries and find the reset button. Usually pressing it in for a few seconds will reset the code to a default like 1-2-3-4-# (or *)
Apr 15, 2018 | Home Security
I have a Brinks Home Security Fire Resistant Safe Model 1060,5055,5060 (Sisco) and I lost the key to open it.Where can I get a replacement key. I have the combination but also need key to open it.
Only from the maker First Alert or a Brinks registered locksmith. They make you jump through a lot of hoops, often including a sworn and notarized letter saying the safe belongs to you.
www.justanswer.com/home-improvement/expert-dr-fix-it
Hi First Alert now handles the fire safe products from Brinks and you may go to the link below to fill the request letter, then have signed at a notary and fax to First Alert for the replacement key to be sent -
http://www.firstalert.com/faqs/safes/how-can-i-replace-the-keys-or-get-a-new-combination-to-my-safe
How to Open a Brinks Fire Safe ' Hunker
https://www.hunker.com > Home Hacks & Answers > Home Safety > Home Safes
May 16, 2009 - A Brinks fire safe uses a dual-lock system consisting of a key and a numeric combination. To open the safe, you have to unlock the combination a specific way, then use the key.
Breaking Into A Brinks Safe - YouTube
? 1:07
https://www.youtube.com/watch?v=GB6Oy5O5yuA Jun 13, 2013 - Uploaded by Inspiring Dreams Daily
Kyle breaking into a Brinks Safe. Imagine the possibilities hahaha Check out the the other videos to see how ...
Brinks Safe Picked ( Lockpicking) - YouTube
? 0:58
https://www.youtube.com/watch?v=DlRfLy6f7sI May 27, 2009 - Uploaded by Anderson Video Production
Up next. How to open safe with lost combination, key, re-purpose repair reuse, part 1 of 3 safe cracking ...
How to Get Brinks Fire Safe Key Sapling com
Jan 29, 2018 | The Home Security
I lost the combination so haven't locked it for fear of not getting it open again
that doesnt sound safe!have you tried emailing the manufacturer with a serial number and model number.to ask for combination.
Apr 17, 2016 | Locks & Locksmithing
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
No override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Nov 15, 2012 | Safe International Sentrysafe X055...
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
Sep 01, 2010 | Sentry Fireproof Safe
Locks & Locksmithing Logo
193 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
