Question about Garden
Need air filter cover for carburater - Garden
    Top Expert:
  • Garden Master
  • 49,958 Answers
Go to a mower shop with the engine serial number and get one.
Posted on May 17, 2015
Idle problem in nissan hardbody ka2400 16 valve
MAF sensor or idle jet dirty or clogged, a can of carburater cleaner through the intake after air filter (while reving) may clean it otherwise a service may be needed.
Jan 22, 2016 | 2007 Nissan Hardbody 3000TD
HARD TO START WON'T REV ACTS LIKE CHOKING OUT
Your problem could be a simple carburater adjustment. Air fuel mixture may be off. There may be adjustment screws on the side of carburater, adjust they slightly to see if this fixes it. If not the carburater itself may be dirty and need to be taken apart and cleaned. Hope this helps.
Sep 27, 2015 | Garden
Where is my carburater?
usually ,,on the left side of engine ,,follow fuel line from Gas tank to Carb ,,,
Apr 02, 2015 | Garden
Where is the carburater
Careers are usually mounted on top of the intake manifold located on the top of the engine. It will be covered by an air cleaner box where the air filter is installed.
Oct 05, 2014 | Cars & Trucks
I have a 2003 Honda forman 450 trx atv, it cuts out real bad as long as the cover is on the air filter. When i remove the cover it runs great The filter is o.k. the carburater has been checked and is
Filter may look OK but it's not if it only takes the cover to choke the engine. Check the choke is opening properly and there are no vent restrictions on filter cover.
Oct 02, 2014 | Motorcycles
1998 artic cat 500 4x4 starts fine but soon floods gas out the carburater overflow
well sounds like you need to clean air filter if that does not help i would go with your choke is sticking on if its a cable pull one make sure its pushing all the way back on carb check or if it is electronic one i would replace auto choke good luck
May 03, 2014 | Arctic Cat 500 4x4 ATVs
Remove missing
clean all fuel filters even the one in the fuel tap
Aug 04, 2013 | 2011 Honda CBF Stunner
Craftsman mower with 6.75 B&S motor will start and run fine for about 3-4 minutes and then slowly chokes out. I cleaned the air filter and need to know what to check next. Thanks.
hi there
though you have cleaned the filter it could still be not getting enough air you can start the machine without it and see if stays running do not do work with it just see if it runs sitting there if it does simple fix new filter however if it does the same it is a lack of fuel either fuel filter if has one if not it will be in the carburater these get gumed up by old gas in which in that case find a small engine repair shop to take care of this issue
thank you for the question hope i helped with the issue good luck and have a great day
Aug 20, 2011 | Briggs 491588 and Stratton Original Air...
1999 GMC Suburban turns over but won't start
It sounds like the choke is the most likely culprit. Take the air cleaner off the throttle body/Carburater. Have someone cover most of the throttle body/Carburater intake, if you don't have help use a piece of heavy cardboard. If it starts up right away it's the choke. Note: if you use cardboard don't rev the engine you may **** the cardboard into the engine.
I'm afraid with all the different types of choke controls I can't tell you how to fix your choke with out actually seeing it.
Jun 06, 2010 | 1999 Chevrolet Suburban
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
