Question about GE Profile 28.5 cu. ft. French-Door Bottom Freezer Refrigerator PFSS9PKY
Ice maker making a weird sort of high pitched circulating sound yesterday and then stopped making sound and ice cubes altogether last night. Would like to fix on own if possible.
    Master:
  • 530 Answers
I would change the filter first. then just get a new ice maker. most are replaceable.
Posted on Apr 22, 2015
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
SOURCE: Ice Maker Problem
sometimes the ice maker works and sometimes it does not work.
Posted on Mar 09, 2009
samrat_babui
  • 296 Answers
SOURCE: Ice maker only makes crushed ice, no cubes
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
Posted on May 27, 2009
Ice maker is not making ice. what could be the problem?
The two most common things that happen: the ice piles up too high, which pushes up the bar that tells it the bin is full and stop making ice. OR the ice sticks to the ice cube maker. If the ice pile is too high, knock it down or empty the bin. If the ice is sticking to the cube maker, try melting it and then spraying it with a non stick spray. Sometimes the water supply line is clogged, but that is not usually the problem.
Feb 28, 2015 | Refrigerators
Why does my new ice maker only make a few cubes?
I don't think your ice maker was the issue sounds like it's not cold enough to make ice in your freezer get a thermostat and see if you are maintaining temps between 0-10F if not you are slowly losing freon somewhere
May 09, 2014 | Refrigerators
Electrolux will not stop making ice.
Sounds like the ice level switch is either jammed on or is faulty.
Look for a flap of some kind that rests on the ice when it's made. Should be located at the back of the hopper.
Jan 07, 2014 | Refrigerators
Ticking sound from ice maker and no ice?
ice maker heater is bad.fingers have rotated to push out ice ,the mold heater did not heatup.replace ice maker.google model no. for rplacement ......always cheaper online
Apr 10, 2013 | Kenmore 52632 / 52634 / 52639 Side by Side...
Frigidaire Side by Side Ice Maker Not Working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
980
May 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer side will not keep ice cream, popsicles or orange juice frozen. it will make ice in ice cube trays-the ice maker makes very few ice cubes.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check
, defrost heater, defrost thermostat.
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 06, 2009 | Frigidaire FRS6R5EMB Side by Side...
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice maker is making weird noise
If it gets louder when you open the freezer door, and seems to be coming from the rear wall (about 2/3 of the way up), then it is probably not your ice maker. It is your evaporator fan motor, which can't really be serviced. The good news is that it isn't too expensive, and it is fairly easy to replace.
Apr 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
GE Profile 28.5 cu. ft. French-Door Bottom Freezer Refrigerator PFSS9PKY Logo
99 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
