Question about Building Materials
I have a Chamberlain AccessMaster 1/3 HP . Door stops when closing at 6 inches off the ground. No blinking lights on the unit, can only be closed by having the door go up/stop it/ then down again.
  • 2,374 Answers
Adjust down force limits
Posted on Apr 22, 2015
  • Ian Watts Apr 22, 2015
    Works now!!! Thanks a mllion !!
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
ltfrc
  • 227 Answers
SOURCE: New Craftsman 95320 1/2 hp chain drive only opens door ~6"
Try this link
http://www.garagedooropeners.us/helpgifs/chamberlain_troubleshooting.html
Posted on May 25, 2009
  • 3197 Answers
SOURCE: Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Posted on Oct 10, 2009
  • 3197 Answers
SOURCE: Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Posted on Apr 12, 2010
  • 3197 Answers
SOURCE: Chamberlain 1/2 HP garage opener main part
If the main light flashes 10 times you have a door sensor problem. Make sure the small light on each sensor is on and not flashing. Tweak them if necessary. If the main light does not flash then you can try increasing the down force just a bit. This is a control on the side of the motor unit where the small gray antenna hangs. If this doesn't work you probably have a bad IR sensor which is a small printed circuit board just in front of the motor.
Posted on May 11, 2010
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when
Check the resistance down button (There is one for down and another one for up). You may need to adjust the sensitivity. That way even if for some reason the have hard time coming down, less sensitivity may solve that issue.
Oct 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Just installed new Chamberlain motor but makes loud snap when door opens and closes about 3 inches from ground?
Do you have a security system in your home? Sometimes the door shut sensors get out of alignment and the door strikes the sensor. This is the exact same problem I had with my door.
Nov 05, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
My garage door will not close. The door gets close to the ground, then starts back up again and when it gets to the top the lights flash.
Just got off the phone from one of the rep's of Chamberlain...Go to the sensor that is blinking(it should be the one with the green light) loosen the sensor until the light goes out, then tighten it back up until the light come back on, and push the garage door opener. it should reset the unit.
Oct 09, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
My door closes fine, but when opening, it only
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped. If so you will also find what looks like white sawdust inside the motor unit.
May 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2 HP door opener will not work (102 1499A))
sounds like the clutch in the motor is slipping, perhaps the chain is getting kinked on something. check to make sure there is nothing in the way of it and that it is on track going into the motor
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opener will not reverse
FIRST YOU NEED TO RESET THE CHAIN .
Unplug power
Release the door from the opener close the door manually. take the chain loose and slide the traveler down to reengage with the trolley. Plug in power, run the unit with chain off untill it completes a clockwise cycle and stops. reconnect the chain and set tension.
Adjust the chain tension.
If it still moves 6-8 inches and flashes 5 times. the problem is in the rpm sensor.
Full diagnostics are in the owners manual - FREE at
http://help.chamberlain.com/help/en-us/InstructionManuals
Oct 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
65 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
