Question about D-Link Print Server Dp-101p
My link light is not lighting up, the other two are ok.
Cigarette lighter socket has stopped working and is linked to the rear number plate lights which are working , fuse is ok please help
either remove it and repair it or fit a new one ,in the bottom of the socket on the back is a thin link connection and they melt for fun so either solder it across with something or renew it ,air pumps are renoun for burning this link out
Jan 30, 2013 | 2005 Citroen C3 1.6
Lincoln ls brake lights not working
Hey Danny,it could be your stoplight switch,it's attached to your brake pedal,here's a link on what it looks like.
Jan 08, 2013 | 2001 Lincoln LS
What could be the problem if my dashboard lights are not working?
If your battery is ok and the ignition on and no lightsCheck fuses and fusable link. Fuses located in fuse box and all should be checked usind a test light with ign on,connect earth clip on test light to a good earth piont then with pointy end of tester touch each side of the fuses. power should be on both sides. Fuseable link located alongside main possitive on battery. sometimes blow and still look ok
Nov 26, 2012 | Cars & Trucks
No data transfer
RESET READ http://www.fixya.com/support/r11153882-general_routers_reseting
Apr 19, 2012 | D-Link DHP-300 Network Adapter
Hi - My 2wire 1701 gateway has steady green power light and steady local network light but the broadband link light is steady amber. My computer is receiving the WiFi signal but I cannot get any internet...
The broadband link light tells you the status of the connection between the modem and the broadband servers in your area. Green means everything is A-Ok while amber means your modem is not picking up a broadband signal.
Try turning the modem off and on and also make sure the cables are secure while you're at it. If the broadband light is still amber, the only thing you could do next is to call your internet service provider.
Oct 01, 2009 | 2wire Computers & Internet
No electrical power to anything - even dome light.
Check battery and chassis earth connections are ok.
Check for 12v power at the fuse/power disrtribution fuse bus; - if no power there, trace circuit wiring back to battery.
Jul 12, 2009 | Chevrolet Blazer Cars & Trucks
Head light does not came on, tile lights get on...
you may have a blown fuse or relay you really need the manual to locate the relay
Feb 14, 2009 | 1995 Mazda Protege
D-Link Print Server Dp-101p Logo
272 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
