Question about D-Link DP 101 Print Server
My lpt light is off. - D-Link DP 101 Print Server
HOW LPT CABEL CONECT TO WINDOWS7
Sir, after connecting the cable to the PC please turn on your PC and go to device manager by right clicking the computer on the desktop.
There you can find scan option it will scan and install all the drivers.
But if you are using laptop or any PC which don't have LPT port then please by LPT to USB cable form E-bay or amazon.
Thanks
Sep 24, 2014 | Epson LX300II Dot Matrix Printer
Have a Samsung desktop - how do I attach printer cable?
It really depends on the specific printer interface you have!
Newer printers can be attached to a Desktop or Notebook via the USB interface (small connector as for mouse).
Older printers, and 'commerciall' high speed printers, have a 'parallel' printer interface (large connector - LPT port) that will connect to a desktop (or higher end laptop) with a parallel (LPT) printer port. If you need a LPT connection, a USB to LPT converter can be used ... but a newer USB connected printer may be a cheaper alternative in this case!
Hope it helps let me know how you go.
Dec 13, 2010 | Samsung NC10-14GW Notebook
CANT GET PARALELL PORT TO WORK DEVICE MANAGER DOESNT SEE IT ?
the laptop bios should support lpt port and if your doesn't have lpt port then you can not use the one for the docking station because no bios integration with the lpt port on docking station
Apr 18, 2010 | Targus Port Replicator, Docking Station,...
Panasonic lPT-51HX42F TV does not turn on but the red light in front is solid red.
The power module may need replacement, but there amy be other problems Panasonic has a code built in if the light blinks count the blinks and they will know the source.
Mar 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
HP Deskjet 920c will not work with my Dell inspiron 1720 with windows vista. The wizard asks which port I want to use but only gives LPT 1,2 or 3. My computer only uses USB. What can I do?
If you really wanted to use it,you have to buy a USB to LPT port or parallel port cable. The other end of the cable is USB and the other end is LPT.
Sep 18, 2009 | HP DeskJet 920c InkJet Printer
How to assign ip to the printer
Using the LPT port is not the same as using the network port. The LPT port does not utulise an IP address.
Plug in a network cable to network port and the printer wil usually aquire an ip address via DHCP.
I repeat the LPT port is not a network port and cant initialise an ip address
May 23, 2008 | Brother HL 5250DN Laser Printer
LPT port
now you have to insert the System CD of the motherboard and when it auto run then install ALL the driver its shows and if the problem countinue then install the port manually using ADD NEW HARDWARE in th control panel.
Dec 02, 2007 | ASUS A7V8X Motherboard
Printer to PC cable
You can purchase an LPT to USB adapter, which connects old printers(parallel LPT) to new cards. Estimate cost is 30-40 us $. You could also get an LPT card for your PC, estimated 20-30 us.
Feb 21, 2006 | HP Color LaserJet 5500 Printer
D-Link DP 101 Print Server Logo
276 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
