Question about Watches
I need to replace my Nike Triax C6 Heart Rate Monitor chest strap and can only find a C10 online. Are they compatible?
2 Suggested Answers
SOURCE: nike heart rate monitor triax c5
I was able to view the instructions here: (no title)
http://www.klokker24.no/ressurser/1183.pdf
Posted on Dec 27, 2008
Tip
Trouble with heart rate monitor reading heart rate.
Can't get a heart rate to show on your heart rate monitor? If there are no other issues with the watch, then most likely what you are experiencing is an issue with the Heart Rate Strap.
It is very common for all brands of heart rate monitors to have issues with measurement.
The #1 reason is poor contact with the strap and your skin. - Make sure the contacts are wet and touching the skin with good contact.
#2 reason - Weak battery, may need to replace.
#3 reason - Sensors on strap have salt build up from sweat - Clean the strap and contacts with soap and water, if deep cleaning is neccessary use a q-tip and some rubbing alcohol.
#4 reason - Strap is too low on the body, raise as high on the chest as possible to just under the breasts. Strap too low will cause a weak signal.
If none of these seem to help, then you should contact an authorized repair center or the customer service for your brand, and see about possible repair or exchange/ return.
on Dec 06, 2010 | Watches
Nike triax watch strap needed wg48 4000 grey strap
I'm having the same problem with the same model. Were you able to find a replacement strap? Thank you.
Feb 13, 2010 | Nike Oregon Series WA0019-001 Wrist Watch
I have a Nike Triax watch and the strap broke. The strap is held on with pins. How do I get a replacement?
Use this link:
http://www.nike.com/timing/?sitesrc=USLP
Select your region, then select support and get the answers. You may try retail locator as well.
Rate me, please.
Jul 29, 2009 | Nike Watches
Nike heart rate monitor triax c5
Nov 17, 2008 | Nike Triax C5 Wrist Watch
Strap Replacement
Maybe you can use it on an armband like with an iPod. Even with velcro.
Jul 24, 2008 | Nike Triax C5 Wrist Watch
Heart monitor
If you have the cheststrap then you don't need anything else. If you don't have the cheststrap piece then you need one. The watch itself does not moniter your heart, It only reads the signal being sent by the moniter on the chest strap.
Mar 28, 2008 | Nike Triax C5 Wrist Watch
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Watches Logo
60 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
