Question about Blenders
How do I remove top cover? - Blenders
    Sergeant:
  • 166 Answers
You did not say what blender you have, but most blenders tops simply pull off.
Try prying up from one corner first. It should come off easily once you loosen one corner.
Posted on Jun 02, 2015
Ninja blender motor part is wore out
-I don't think they carry any replacement parts for Ninja Blender.
-Possibly not the spline plastic.
-Inside on top of the motor there is a planetary gear there. Possibly worn out or lose screws as well that not hold it in place to mesh together.
-But before you can reach to these parts you have to take the bottom cover off, remove the plastic spindle. IT's very tight.
Good luck
Mai
Jan 11, 2018 | Euro-Pro Ninja 1000 Watt Prof Blender 3...
The plug has sheared off,can I have it replaced by an electrician or do I have to return it to Bamix.
Remove the 2 screws on the top cover with a security torax screwdriver.
The cord and switch assembly will lift out quite easily.
Solder on the new cord.
Put the cover back on.
Jun 11, 2011 | Bamix Deluxe Handheld Blender
My K-Tec Champ HP3 is overloading and shutting off after about 5 seconds even with the jar empty or not even on the machine. It just starts up and shuts off (displaying "OVERLOAD" on the...
Remove the 2 screws from the bottom of the base, release the 4 clips on each side and remove the bottom cover.
There is a fan blade attached to the bottom of the motor and a sensor on the side of it that senses the fan blade turning. If the sensor does not sense the fan blade turning, it assumes that the motor is locked up or 'overloaded'.
Check that the fan blade has not come loose from the motor shaft and reattach if necessary. Verify that the sensor is secure in it's housing next to the fan blade.
Reinstall the base cover and verify operation.
Jan 24, 2011 | K-Tec Champ HP3 Work Top Blender
Braun 4166 household blending mixer How do you take this apart?Disassemble?
1. Remove two small plugs on top, digging a wood screw into the soft plastic. They cover two screws.
2. Remove the screws.
3. Remove the cover.
4. Remove two screws holding the motor housing to the foot.
Dec 21, 2009 | Braun MR 300 MultiQuick Blender
What to do with the Total Blender when overload appears?
The product has a 3-year warranty:
A reading of “OVERLOAD” indicates an overload on the motor. Turn off
and unplug the unit. Plug in the unit and turn the motor on again to clear the
over-load condition. Check the blender jar for blockage. If overload condition
re-occurs, contact your Blendtec service agent.
Mar 25, 2009 | Blendtec ABC Work Top Blender
How do I change to clutch on this blender. The outside of the clutch broke off leaving just the screw head on the blender, when I turn to unscrew it, the entire piece just spins, any suggestions.
You can probably use a Vise-grip pliers to clamp down on the brass insert and unscrew it. Not only is it on very hard, but it is also threaded reverse of a normal screw. This is so it does not come undone in normal operation.
You have to turn it counter-clockwise to unscrew it (a regular screw turns clockwise).
I had to clamp the motor shaft real tight with a bench vise to be able to remove the clutch. Hope this helps.
-Vince
Aug 14, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart CBT-500 blender won't work
(0) unplug unit (1) Remove the bottom 4 screws, cover plate and motor shield ( 2) unhook the white motor wire from its binding clip ( 3) locate the plastic sleeve with the fuseable link (4) cut the sleeve and test for continuity between points on either side of link with ohmmeter (5) if no continuity, clip out fuseable link and and solder the white wire back together (6) cover with tape (7) rebind to other wires (8) replace bottom and check. This worked for me.
Apr 13, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Removing the plastic top service plate
if the motor is running and the blade is not turning here is a rubber coupling that has probably broken.the blender will need to be pulled apart and that part will need to be replaced . it is designed to absorb sudden shocks if something hard is hit and has broken rather than burning out the motor. there are two other torx screws holding the rest of the plastic parts after the switch assy is removed by uncliping it .
Nov 18, 2007 | Bamix Gastro 200 Handheld Blender
DeLonghi DBM8150 problem
These instructions disassemble an electrical appliance. You should have some technical/mechanical/electrical experience to attempt this and you do so at your own risk.
See exploded diagram : http://www.kenwoodservice.co.uk/uk-delonghi/exploded/exploded-KF8150M.pdf
This is not a very good diagram to show the disassembly, however, it will at least help me to identify the parts.
Prise out the center insert in the drive wheel (#15 on the diagram) on the top of the base unit (I used a paring knife and worked my way around the circumference to work it loose).
Remove the four rubber feet (#19) from the base by pulling them out.
Undo the 4 phillips head screws in the holes where the feet were.
Remove the base and carefully position it along-side the body of the blender.
Prise off the silver switch knob (#13) - it slides straight off the switch shaft and I used a screw driver to carefully lever it off, working from each side a little at a time.
Undo the drive wheel on the top of the drive shaft by holding the fan on the bottom of the drive shaft and turning the drive wheel CLOCKWISE.
Undo and remove the two screws holding the switch support (#11) and cut the tie wrap that secures the blue cable to this support.
Undo the four screws that secure the motor assembly to the casing and remove the screws and their shake-proof washers.
Remove the internal components as a single assembly. Tilt/angle the motor assembly towards the switch support until the top of the shaft clears the rubber boot in the top and then the whole lot comes out easily.
To replace the switch (Part No. HS1144 - #10 on the diagram):
Carefully lever the white gear wheel off the switch shaft.
Undo the two small screws that hold the dial gear wheel cover in place on the switch support.
Remove the cover and the small gear wheel (noting which way around the gear wheel goes the two ends of the shaft are slightly different).
Undo the nut on the switch shaft that that secures the switch to the support (nut is 14mm diameter and needs a thin wall socket. I used long nose pliers to remove and re-install it).
The wires connect by simple push fit into their slots and the angled brass blades inside the slots grab the wire and lock it in place. To withdraw each wire, use a very thin screw driver (or similar) to depress the brass blades inside the slot. This enables the wire to be withdrawn as you depress the blade.
Re-assembly is the opposite sequence.
When putting the dial back together, remember to check that the dial reading lines up with the switch position (adjust the gears by resetting the teeth if the alignment is not correct.
Here’s the really interesting thing. After I replaced the switch, I pulled the old one apart. IT HAD FAILED BECAUSE THE CONTACTS HAD BURNT OUT. They had obviously been arcing and had completely burnt through. There were burnt off tails of the contacts lying in the switch housing and there was evidence of burning (carbon deposits) inside the switch. In short – the switch is not up to the job and will fail. Poor design and a latent defect.
Aug 17, 2007 | DeLonghi DBM8150 Work Top Blender
Blenders Logo
130 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
