Question about Cub Cadet Garden
How do you remove a seat on a zero turn rider?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Lift seat there is a latch behind the seat. If it's a cub cadet there a few different ways. Some just slide off the others have bolts where the seat is hinged
Posted on Aug 17, 2016
Will not fire, turns over...like no spark
Check to see if there is a safety switch under the seat. This shuts the mower down if the rider falls off for safety. You can test the switch by unplugging it and jump the connections together at the end that is attached to the engine. If it runs in this condition you need a new safety switch in the seat.
Jul 18, 2016 | Husqvarna Mz6128 61" Ztr Lawn Mower Zero...
Remove the seat on yamaha raider
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Stupi question time How do you remove the seat
2013 Yamaha Raider passenger seat removal
http://www.starmotorcycles.com/assets/service/manuals/2009/LIT-11626-22-58_Raider_S_1651.pdf
OEM parts for Yamaha
http://mazko.net/docs/bikers/XV1900-RoadlinerStratoliner06-09REPAIR-MANUAL.pdf
Dec 08, 2012 | 2011 Yamaha Raider S
How do I remove the rider seat from my 1998 honda cbr900rr
Hi, Chris for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-fireblade/44362-removal-seat.html
How do you remove the damn seat
Honda CBR900RR Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR900RR FIRE BLADE Owner Manual
Dec 08, 2011 | 1998 Honda CBR 900 RR Fireblade
How top remove seats
  • Lift the rear of the passenger seat's cushion to find the screw that secures the seat to the rear fender. Use a 5-mm Allen wrench to remove the screw.
  • Lift the rear of the passenger seat slightly and pull it away from the rider's seat.
  • Use the 5-mm Allen wrench to remove the screws from the rear of the rider's seat.
  • Lift the rear of the rider's seat upward slightly. Pull the seat back until the tabs on the front of the seat separate from the motorcycle's frame.
  • Mar 27, 2011 | 2005 Suzuki Boulevard C50
    Hello I have a toro zero turn rider z4220 I think I bought it new about 2 to 3yrs ago when I was putting it up last winter the left drive would not go forward or reverse then shortly there after the right...
    Hello, W/D here.
    Look for a transmission disconnect rod, usually at the back of the tractor, about even with the top of the gearbox. If it has been moved to the out position, the transmission will not operate from the seat, but you can push it.
    Good luck, --W/D--
    Mar 17, 2011 | Toro Zero Turn Rider 74366 Lawn Mower...
    Just bout a used '02 vmax. I put stock seat back on. Now the release for the gas tank is not working. Any takers on how to get it off to look at what is going on?
    From Orig Owners Manual on how-to :
    Read carefully and hope it helps.
    Fuel tank cap
    To remove the fuel tank cap
    1. Push the levers on the left and
    right side of the rider seat backrest
    as shown and slide the rider seat
    backrest forward.
    2. Insert the key into the lock, and
    then turn it 1/4 turn clockwise. The
    lock will be released and the fuel
    tank cap can be opened
    To install the fuel tank cap
    1. Insert the fuel tank cap into the
    tank opening with the key inserted
    in the lock.
    2. Turn the key counterclockwise,
    and then remove it.
    3. Slide the rider seat backrest rearward
    and push it down.
    NOTE: @
    The fuel tank cap cannot be installed
    unless the key is in the lock. In addition,
    the key cannot be removed if the cap is
    not properly installed and locked
    To install the rider seat
    1. Insert the projection on the front of
    the rider seat into the seat holder
    as shown.
    2. Place the rider seat in the original
    position, and then tighten the bolts
    and screws.
    NOTE: @
    Make sure that the seat is properly secured
    before riding.
    3. Return the rider seat backrest to
    the original position
    Mar 22, 2010 | 2002 Yamaha V-Max
    How do I remove the rider seat to access the battery?
    with the key on the left hand side down by the ridder seat turn the key and pull up on seat sometimes to get the key to turn you have to push down on the rider seat
    Mar 20, 2010 | 1997 Yamaha Royal Star XVZ 1300 A
    Need to remove seat to jump battery...how do I do that?
    There is a bolt at the back of the passenger seat, you remove it and slide the seat to the rear This will expose the bolts at the rear of the rider's seat, remove them and slide the rider's seat back. There's your battery.
    Oct 25, 2009 | 2007 Suzuki Boulevard
    How do you remove the riders seat from a Yamaha
    look under the back corners of the seat. I think there are two allen bolts there
    Jun 15, 2009 | 2003 Yamaha Road Star Silverado
    Raise the seat
    First take off the seat, turn it upside down, unscrew the two screws and two bolts that hold the two parts of the seat together. Separate the pillion and rider seat (takes a bit of wiggling), now you can concentrate on the riders seat. undo the four screw that hold all the rubber gromets down (make a note of the direction they are facing), and unbolt the two small bolts on the front. The seat should now come apart, move the bracket at the back of the seat down a hole. Re-attach the two halfs of the seat at the front but this time one hole up. You should see a gap between the two halfs. Put the rubber gromets back on, this is where I went wrong the first time, TURN THE FRONT TWO 180 degrees and leave the back ones how they are. Screw everything back together and you have one raised seat my long legged friend.
    Nov 10, 2008 | 1997 Suzuki GSF 250 Bandit
    Garden Logo
    59 people viewed this question
    Top Cub Cadet Garden Experts
    Tim Whalen
    DarkfireVA
    Level 1 Expert
    Matt Olenzek
    Matt Olenzek
    Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
