Question about Kitchen Ranges
If I replace a range hood should I get good updraft if I reduce a existing 8 inch pipe to 6 inches for the new range hood. The ADKY I just bought was an excellent price
  • Anonymous May 30, 2015
    Thanks for info
  • Kitchen Ranges Master
  • 2,760 Answers
According to bernolii's equation air velocity increases as pipe dia decrease's given that force(fan) remains' the same
aka it's gonna make a lot more noise !!
Posted on May 30, 2015
rockitman187
  • 2559 Answers
SOURCE: Electric service requirements
You will need to pull # 6 copper for 50 amps of service,The stove does require 50 amps and # 8 can't supply that.
Please take time to rate this fixya.
Posted on May 11, 2009
heatman101
  • 43501 Answers
SOURCE: i have bought a ge gas range moldle # jgb805depbb
Yes if you are only going 30 feet with the 1/2" black iron you will be fine.
This will give you all the gas you need for your range.
Heatman101
Posted on Jan 24, 2010
tbreeze47
  • 3083 Answers
SOURCE: I've purchased several drip pans
This web page has the diagram for your range, and also the 8" drip pans in stock at $15.23 each:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212798&diagram_id=21217125#d21217125
Bookmark this page and add it to your favorites, it's really helpful having the diagrams and parts' lists to go with them.
I would contact them and tell them your problem. They may know what's going on and find something that will work for this crazy situation.
Maybe this site's pans are compatible, hopefully.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 08, 2010
TheMobilian
  • 8220 Answers
SOURCE: burner will not get hot enough
When the burner arced out it probably also ruined the switch. Most switches on a standard electric range have 5 wires. 2 wires to the burner. 2 hot wires from power and a smaller wire which connects to the indicator light marked P. It is easy to test the switch Unplug the stove. Turn the suspect switch on wide open. Check for continuity between the 2 terminals going out to the burner marked H1 and H2
If you cannot get a reading then the switch has failed. Note: when replacing the switch usually on most stove the replacement will not be or look like the original HOWEVER it will still have L1 and L2 H1 and H2 and P but the terminals are not always in the same order. If you fail to correctly connect the new switch you will fry 2 switches when both get turned on. Ouch!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 30, 2012
SOURCE: Inner 6-inch element on the 12 inch/6 inch Dual Radiant Element cycles off too long
Sounds like the file is corrupted. That doesn't mean the footage is irretrievable. I believe the file type is .mov on that camera? You need to find a .mov repair program, there are lots out there. I don't want to give you a link since I haven't used any of the .mov ones and don't want to accidentally give you malware, so I'll leave that part up to you. But you should be able to get your file repaired, just google ".mov repair."
Posted on Nov 15, 2013
Best way to install a 30 inch range hood
The pipe size on the old one was 8 inch and you are putting in a 6? There are no issues with that. IF it was the other way then the pipe was 6 and the hood was 8, there would be an issue. Ductless systems vent the vapor back into the room and there is no benefit from it other than to reduce the steam. If there is a metal filter grid from scintillated metal then it will attempt to catch the grease vapor because it is a lower temp.
Feb 05, 2018 | Kitchen Ranges
In which size surgical gloves are made?
Surgical gloves sizes range from 6 inches to 8 inches in increment of 0.5 inches. The variety of size options are made in order to ensure the best fitting gloves.
Feb 06, 2013 | Clothing Accessories
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
I just bought it and delivery man said he could not install it because my vent out of the roof is only 3 inches. Can I just use aluminum tape to secure the vent hose?
Local code determines the minimum size for dryer vents. Often this is determined from the manufacturer's requirements for the appliance. As you may have guessed, this is pretty much the standard for dryer manufacturers.
If you were to "adapt" the dryer's 4" pipe down to your home's existing 3" pipe, you would reduce the pipe's area from 12.6 sq inches to just 7.1 sq inches (radius squared x 3.1415). That's nearly HALF the required area that is required. Your clothes dryer will suffer. Drying times will increase dramatically as there will be less air flow. Electric / gas usage will increase due to the longer running times, and there could be significantly more heat inside the dryer that could be a fire hazard.
Don't do it. Either invest in the correct size dryer vent, or use another venting method instead of reducing the pipe size.
I know it's not what you wanted to hear - but I hope this helps. Please rate my reply - thank you.
Mar 09, 2011 | Dryers
6 burner propane fed will not allow all burners to produce a usable flame for cooking,grill is not hot enough
I need more information, but I suspect you may not have a large enough regulator on your propane line. The only way to know for sure is to attach a gauge called a manometer onto the manifold that feeds the gas burners. There is a 1/8 inch pipe fitting on the manifold for this purpose. It should read 10 inches of water column. You need a capacity to run about 300,000 BTUs when everything is on at the same time. This requires a large capacity regulator. Also the line from the regulator to the range should be at least 3/4 inch pipe.
Sep 12, 2010 | Vulcan VG260 Gas Kitchen Range
I have bought a ge gas range moldle # jgb805depbb i need to know what size diameter black pipe to run from existing run, 30 feet to the new stove. is 1/2 inch large enough to supply the unit
Heatman101
Jan 24, 2010 | GE Kitchen Ranges
Size of vent pipe
You will be fine with 2 bends in an 8 inch pipe. If you bend it more than 3 times though you will loose fan force. If you up to a 10 inch duct you will not have good fan force because the space is bigger.
Good Luck and Please Rate FixYa!
Feb 25, 2009 | Fantech Fan FG8XL
Viking 10 inch hood lights out
It is more than likely the dimmer switch has gone bad and needs to be replaced
Nov 06, 2008 | Viking DTWL4848 Kitchen Hood
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
