Question about Philips Televison & Video
Tv is flickering with horizontal stripes on the left side
I wanted to take the front off so i could see if a contact is lose, but the damn front just doesnt want to come off!! please help mee!!
  • Philips Master
  • 1,103 Answers
  • 905 Answers
SOURCE: two black stripes with colored stripes inside
yes it can be fixed! , it is not the screen , so that it good news for you!
just call your local repair shop , and if you have a warranty then use that and they should come out to your house to do the repair , but they may have to take it in, just depends on what they find and if it would be easier to have it in for testing
electech
Posted on Nov 05, 2008
budmrtn
  • 11361 Answers
SOURCE: Different colored stripes on TV screen
You have bad T-CON board.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 27, 2010
  • 10 Answers
SOURCE: Our plasma tv has a
Most stores will only give you 30 days to return something. You obviosly have either a bad plasma panel or a scan board. Either way you should have a manufacturers warranty. Contact the store for that info.
Posted on Oct 22, 2010
  • 64 Answers
SOURCE: My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Posted on Dec 29, 2010
caroldon
  • 17130 Answers
SOURCE: coloured stripes all down left
This is failure of some capacitors in the circuit . There are electrolytic capacitors which loose value in time or it is due to defects in the production resulting in leaks causing lowering of value. When the circuit is powered the capacitors slowly regain power to get back to the near value and hence the circuit behaves properly . Have visual check and change any suspected leaked capacitors. If not use a hair dryer to heat suspected section , if the fault clears on cold start change capacitors in this section.
Posted on Feb 02, 2011
Samsung LE40D550K showing horizontal glitches
If you wish to get more details visit the site linked here. Display d
faults of many popular brand tv sets are given in detail with illustrations. http://electronicshelponline.blogspot.com/
Jan 26, 2017 | Samsung Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
ESN PCTV000121==9453ACB01D4EB8D9D185
get another tv or call a expert for it
Dec 22, 2013 | Panasonic Televison & Video
How do i adjust the alignment of blade on Dewalt wet saw
That's easy to do it , all you have to do is lose three screws on the left side of the track. There are four screws, on each track, you have to start from the front to the back. Don't lose the Last one. The four one. Then there's one screw under of the rails. going horizontal. It's going to be in your left side. You have to do is just screw in. Ifyou want to open it. Screw it out if you want to close it.
Sep 29, 2012 | Dewalt D24000S HeavyDuty 10inch Wet Tile...
Led problems
Why do I have a green line on the edge of my screen? If you have a thin green line on the edge of the screen when using an HDMI cable to connect to a cable or satellite box this is usually caused by the box.
To test to see if this is a box issue you will want to take the following steps:
If the TV has a Horizontal position setting in the menu you can adjust the position to see if the line disappears.
You can also change the Wide setting to the Zoom or Panoramic option to see if the line disappears.
If the line disappears you will want to look into getting a different source box.
Your display may be flickering for several reasons. You will want to take the following steps to rule out the most common reasons for the display to flicker:
1. Reseat all cable and connections to the television from your devices. Physically remove the cables from both the television and the device and reconnect them.
2. Check your Advanced Video settings in the Vizio TV menu some of our Vizio televisions will allow you to adjust the following settings under the Advanced Video settings:
Ambient Lighting
Backlight Control
Advanced Adaptive Luma
If you have any of these options available please turn all of them off to see if this resolves the display flickering.
If the above steps have not resolved the issue please take the following steps in the order presented:
1- Power off TV
2- Unplug TV from outlet
3- Press and hold in the power button on the TV for 30 seconds (while it is unplugged from the wall)
4- Release the power button
5- Plug in the TV into a different outlet
6- Power the TV back on
There is also a factory reset option in your menu under the SETUP section. It will say either "reset all settings" or "system reset". We recommend that you reset all settings as well to see if this resolves the issue. If this does not resolve your problem please contact our technical for further assistance.
If the line stays in the same spot when changing the above settings please contact our technical support.
Dec 04, 2011 | Televison & Video
Installing stero in car wiring diagram front soeakers 1999 mercury mountainer
your right front speaker neg side is Green with a orange stripe your right front pos side is Light tan with a green stripe your left front neg side is a light blue with a white stripe and the left front pos is orange with a green stripe,, a typical new radio will have a gray with a black stripe for the neg side and solid gray for the positive, on the right side and the left will have a white with a black stripe for the neg, and solid white for the positive, if you need anything else just reply to this feed and I'll help you
Oct 07, 2011 | 1999 Mercury Mountaineer
Black strip
If all the color alignment is correct ( Convergence is right ), it sounds like you may have a problem ddeveloping in the horizontal section. You might want to seek professional help before the circuit fails and the set quits. It could be more costly if you wait to long. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
