Question about Refrigerators
Hi I have a couple of things happening & the more I read the site, I can see I have to be better at asking the questions
I have found there is a leakage of water from a vent between the freezer on top & the fridge below. The freezer works perfectly the fridge does not cool at all. The vent between the freezer & fridge is not dirty & there is no build up in the polystyrene drain trays. There my ability to describe ends except there is a yellowish stain in both trays under the vent cover & a chemical smell. There are no other bad odours or stains it is a spotless unit
  • Refrigerators Master
  • 5,323 Answers
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Posted on Apr 22, 2015
Testimonial: "wow"
Why do I get hundreds of responses but not the one I asked for
nobody out here in fixya site land knows what you want as an answer
but then again if you know the answer --why ask the question
May 28, 2017 | The Computers & Internet
My device no longer connect to my home wi-fi signal
Not enough information. Various thing could cause this issue. Give a better description of what's happening, rephrase your question. Reset your network settings.
Good luck and thanks
Questions? Just ask! Mr.Mike
Nov 27, 2015 | Alcatel One Touch Fierce 2 7040N...
How to get my badoo account unblocked?
You better read their terms and condition because maybe you violate their rules on their site and check also if you are blocked, better check their frequently asked questions, there is a possibility that your are permanently blocked. Maybe badoo is blocked in your country. Try to signup a new account
Mar 10, 2015 | badoo Android Apps
I ONLY READ ADS ON CRAIGSLIST.NEVER POSTED ANYTHING WHY AM I BEING BLOCKED FROM THERE SITE
good question but then again what are you asking that question on this site for. would it not be better to ask the craiglist site for an explanation.
Mar 08, 2015 | Cars & Trucks
95 Chevy suburban, check engine light will come on
First thing you need to do is get the fault code read. Autozone, etc will read them for free. Once you have a fault code, come back and ask a more specific question with your fault code. We need more information to give better responses. The more specific you are, the better chance of success. Which gears will shift, Which won't, what speeds, etc.
Aug 31, 2014 | 1995 Chevrolet Suburban
Remove carb 01 heritage softail
Absolutely!
Now for a BETTER ANSWER, ask an ACTUAL QUESTION, providing greater detail as to the issue you are encountering.
The only thing unique about removing and replacing the OEM carburetor on the bike is the Bendix tool you will need to adjust the metering, which can be found on the Internet. Otherwise, it is a straightforward and fairly simple thing, and most after-market carburetors such as the S&S can be ordered with proper jetting and metering for the engine!
Let me know is anything specific you need help with. I've done a couple of carb updates on that era of Harley, so I may be able to provide some specific advice for you..
Feb 13, 2013 | 2000 Harley Davidson FLSTC Heritage...
I am a sevicer and need the schematic
After reading this repost your question...
Here is a tip that will help you to get better results from your question on Fixya.
How to ask a question on FixYa
heatman101
Feb 01, 2011 | Microwave Ovens
Hi there I seem to have lost the instructions for my goodmans cuisine GBM6255-Hinari Domestic H13904. Is it possible to download a new one...Ruth
After googling I found an answer!!! I went on the web site www.answerbank.co.uk and asked for the instructions... Someone had already asked the same question... The answer was that breville took over the model and if you ring this number 0161 621 6900 and say you need the instructions and recipes for the breadmaker model breville BR8L which happens to be the same as the Goodman cuisine GBM625-Hinari Domestic H13904, but would suggest you don't ask for Goodmans or Hinari!!! They will send you an email with the instructions and recipes as an attachment.
Mar 25, 2009 | Kitchen Appliances - Others
My problem with garmin c510 deluxe not charging has been fixed
Just posting this to take your question out of the unsolved section. I hope it is working well now.
Aug 02, 2007 | Garmin StreetPilot c550 GPS Receiver
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
